New Tractor / New Videos!
/ New Tractor / New Videos! #1
Avenger
Veteran Member
North Idaho
LS XR4145C
I made a few videos of getting my new XR4145C a while back, but never uploaded them to YouTube.
Yesterday, I made another one (4th one) and uploaded them all just now. So, if you would like to see my new (-er) toy...
LS XR4145C - YouTube
/ New Tractor / New Videos! #2
Enjoyed the video's. I'll keep an eye out for more.
/ New Tractor / New Videos! #3
Nice informational videos, showed a lot of pros and cons. That cab is a luxury I wish I could afford, mostly for plowing snow. Have you got a snow plow for it yet and what a bout the front tire rubbing on the loader mount, what's the fix on that are the front tires the right size? Front tires should not rub on anything at anytime on anything.
Thank you for the kind words!
The cab was actually not that much more. And after speaking with the dealer about how many windows he sells or replaces due to the glass breaking, he put my fears at ease. (Also, spoke to others.) But yeah, I cannot wait for winter! I tell people I am going to, at least once, plow my driveway wearing flip flops and shorts, just because I can! I currently do not have a snow plow. I only have a box blade and the bucket. That should be enough until I can get an actual plow. I do have a plow on my 4-wheeler, but who would want to use that when they have a cab tractor?!
On the tires, that is a very good point that I never considered. I will check the tire size when I can. I will also attempt to make another video showing that rubbing, it may be a bit difficult though.
Thank you for watching, and keep an eye out for more!
/ New Tractor / New Videos! #5
Just get your front tires to the point of rubbing, jump out and video. I just can't visualise your problem either.
I made a quick video showing that issue with the tires binding. FYI.
/ New Tractor / New Videos! #7
Thanks for sharing :thumbsup: looking forward to more updates.
/ New Tractor / New Videos! #8
Thanks for that rubbing tire video. Must pay attention to my 3135 to check for same. Should not even be able to do that.
/ New Tractor / New Videos! #9
My XR3135 has front tire angle stop bolts. Perhaps yours are missing or out of adjustment. You should not have such a tight turning radius either. Mine supposedly has a 48 degree turning angle. You should be able to adjust the stop bolts if you are having fel interference.
/ New Tractor / New Videos! #10
My relatively (less than 3 month old) XR4155HC doesn’t exhibit the tire binding-iirc I have the stop bolts previously mentioned. I will have to look closer next time I get over to my Spokane property.
BTW-LS must have made a few small changes in the next model year ( I am guessing yours is a ‘16)-I have 3 rear remotes and don’t seem to have the odd curl issue with the FEL.
I am thinking of the speaker upgrade and wonder if you could elaborate on the issues you alluded to.
Good luck with all your projects! I am in the midst of septic system backfill at my place so the LS is getting a good workout!
PS-I ordered the beacon light through the dealer where I got my tractor and got it in less than 2 weeks. If you’re still trying to get the three point lever PM me and I’ll give you the name/number of the parts/service manager-maybe he can help you out.
/ New Tractor / New Videos! #11
With the tires binding like that there is definitely an issue with something. I would contact your dealer if you haven't already. That could create some major issues with the front axle, tractor frame or loader.
My relatively (less than 3 month old) XR4155HC doesn稚 exhibit the tire binding-iirc I have the stop bolts previously mentioned. I will have to look closer next time I get over to my Spokane property.
BTW-LS must have made a few small changes in the next model year ( I am guessing yours is a ?6)-I have 3 rear remotes and don稚 seem to have the odd curl issue with the FEL.
PS-I ordered the beacon light through the dealer where I got my tractor and got it in less than 2 weeks. If youæ±*e still trying to get the three point lever PM me and I値l give you the name/number of the parts/service manager-maybe he can help you out.
I will send you the PM for the lever. Thank you.
I have a 2018 model. The floppy bucket is just something I have to get used to I guess.
The speakers: after I learned how to open the top of the cab, I started to think this was not such a good idea. There is absolutely no room up there! After I removed the old speakers, I had to dremel out the plastic, maybe 1/4in all around, for the new larger speakers. The speakers are held in place with small screws with nuts on the back. Trying to get those nuts on while balancing on a ladder, reaching around hoses and trying not to drop anything, was a major pain. But totally worth it.
As far as the stop bolts, I will need to research them. I am not familiar with them. I recently came in a shop manual, hopefully there will be something in there. Thank you!
/ New Tractor / New Videos! #13
Yes, I believe the angle stop bolts are there for the exact purpose of having some adjustment when adding the front end loader. Hard to believe any one would buy one without it.
Well, when you dont know, you dont know. I figured it was just part of the tractor to be aware of.
I am not seeing the stop bolts in the shop manual. Where on the front axle would they be located? I am not currently at my tractor, and wont be until later today. I am just trying to figure out where they might be. I probably will call the dealer, but I am not having very good luck with them for other things.
/ New Tractor / New Videos! #15
Here they are on my 3135: IMG_20180820_115305.jpg see the threaded bolt and the stop. Left side:IMG_20180820_115305.jpg
/ New Tractor / New Videos! #16
Whoops! Here is the left side, looking straight down:IMG_20180820_115029.jpg
Thank you!
I think I did find it in the shop manual. It is not under the front axle section, but rather the hydrolic section. Go figure.
And, there is not much about it. Just a mention to make sure you measure it before removing it.
I went back and watched my last video again. I paused it at 0:52 and you can see the stop bolt. However, I paused it again at 2:23 (other side) and I think, that looks like a stop bolt turned all the way in? I didnt get a good shot of the front of the axle on that side. I will scope it out really well when I get home.
This has been absolutely wonderful! Thank you everyone who has contributed. I did not think this was an issue. I mean, I thought that was just the way this particular tractor operated :duh:. But due to this community, I have identified a potential catastrophic issue that requires resolving. So thank you thank you thank you!!
/ New Tractor / New Videos! #18
Thank you!
Cool Beans! I would think, that if out of adjustment, it would really stress out the hubs and possibly snap them.
Just posted an update video. This time, I explore the steering angle using a hastily put together steering angle finder I learned from ChrisFix. That did not work. However, I did find the steering bolts and now I am left with more questions. I am wondering how far out and can move those bolts and, even then, would it still get bound up? I am probably going to move them out and test it, but, should I be contacting my dealer? How far out are your steering stop bolts? Could something else be going on?
/ New Tractor / New Videos! #20
My steering angle bolts have a little over an inch of thread showing. Something I read stated that to properly adjust those bolts, you are to raise the front of the tractor with a sling so that the front axle hangs so that it can be articulated through its entire range of motion to check for rubbing or binding.
