new tractor idea possibly....
/ new tractor idea possibly....
100th diagram...
ouchers... i am completely out of ideas... of how to deal with the implements... on this new setup.
is there 2 hyd cylinders on each side. and they play hot potatoes. and pass implement back and forth between them when implement is up above the STB, to move implement from one side to other side...
discs would be fairly easy, just a hyd cylinder or 2, and you can quickly adjust angles of all the gangs of discs.
but for chisel plows, rippers... were they are J shape. planters that have boxes... and some sort of spring that pushes down into the ground... reset springs for plows / rippers...
there is normally a single pipe that goes entire width of the implement. and chisles / rippers / discs get hung off of. perhaps instead of using box shape pipe. going with pipe O in shape. so these rows can be rolled over per row 180 degrees.
to state it, some sort of "crane" that does the moving of each implement from side to side and also turns implement 180 degrees...
does the STB act like a earth worm. getting shorter in length in field mode. and then longer in transport mode. and this switch from short to long. involves implements rotating from side to side...
is there 3 sets of hyd cylinders. 1 set on each side, to raise / lower, and adjust implement when it is down in the soil and then the 3rd set to flip the implement over to the other side...
i guess i am off to google regular old trains. and see if some pictures / video's give me some ideas... due to at this moment completely stuck in my tracks :/
*rubs chin* thinking about it.... perhaps a different setup needs to be considered... for the wheels. to keep the "height" of the wheel modules. from not being as high. so more of a "over the wheels" flat bed trailer type of setup could be done. but without the sheet metal / lumber for actual floor of the trailer. just the frame work... and supports for holding implements.
i realize large AG type tires always looks COOL! but really... can you get away with say 2 feet in diameter tires. (2 feet high tires)
ya agriculture / field tractors will see mud. but if a field is that wet... are you really going to be out there in the field making ruts?
about only thing that would come close would be furrows when using a bottom plow. but even then. you should be sinking tires to the axle that goes into a wheel.
i guess other thing would be "ground clearance" when units go up and down steep hills... were the distance between each wheel module would have to be considered.
trying to justify things....
if i go with a train flat bed like trailer unit. and keep ground clearance say 12 inches. and wheels are 24" in diameter plus another say 6" above wheels to keep mud from clogging up on things. 24 + 6 - 12 = 18 inches.
i would most likely need to go up few inches above each wheel, to deal with 360 joint. lets say 6" inches and then a few more inches to deal with a drive shaft or hydrostatic transmission or electrical motor. lets say another 6 inches.
24 + 6 + 6 + 6 - 12 = 30 inches between top of the flat bed, and ground clearance. i could fit hyd cylinders that move wheels in and out for weight adjustment, engines, fuel tanks, radiators, hyd oil coolers. in that 30 inches... this would really lower COG (center of gravity) from being high up. to really low to the ground. and reduce tipping.
i would imagine the frame work between each wheel module. could some how be done to extend or contract the frame. so different width implements. could be done up. some implements require more HP, traction, weight, while others do not.
it is not like farmers have not seen wagons and some implements that you can adjust length wise in the frame work. and it is left to the farmers to adjust distance between axles on a wagon, to put a flat top wood or metal deck on them...
but for STB tractor. this length adjustment may only happen between switching implement types...
some pictures from a quick googling for "train equipment" and then clicking over to images....
got a kicker in thinking about this huge long crane (what ever special name it has) swings multi implements from side to side. then i thought about the weight placed in that single spot... *waves by by to the crane base as it sinks to center of the earth*
below image is from Assorted Brass Work Train Equipment and Specialty Cars | OVERLAND MODELS/ORIENTAL LTD., CA. 1980'S AND 1990'S | Maritime Pictures Auction</li>
gave thought to implements folded up on the STB during transport mode.
Old Train Equipment Of The Pichi Richi Railway Stock Photo 56817349 : Shutterstock
not really sure about. looks to be some sort of "man lift" to work on over head signs and signals that may go over a railways... thought maybe some sort of 360 spin to spin implements from side to side..*shrugs*
below image is from Railroad repair equipment. South of Rome, Italy - sprockit's Photos
maybe some sort of crane is used to move implements form side to side and into transport mode. and thinking maybe some sort of quick attach thing instead of a generic chain hook...
below image is from Lifting and rigging Australia. Allways Rigging. Rail lifting equipment
Franck-Marczan-Managing-Director-Allways-Rigging.-Lifting-and-rigging-Australia.-Rail-lifting-eq.jpg
MULTIPULE images from same webpage....
below 3 images are from http://www.raillynews.com/2012/07/10/
gave thought to going with "flat bed" trailers and shrinking overall height at the wheel modules.
gave thought to a mount crane on the STB... don't know about this...
had to post it, grain wagon on train tracks.... if you could only remove the tracks...
i have seen it done a lot of times more so on youtube and google images. and that is some sort of excvator or skid steer loading itself onto back of a trailer. without ever putting ramps down.
the below picture gave me thought, if cranes are used to move implements from side to side and place into transport mode. why not use the crane to act like the "links" between each section.
other words, if ya using a crane to move implements back and forth they will most likely have some sort of quick hitch / connector on them for implements. why not take things one step further, and put quick hitch on ends of each section for crane to attach to...
below picture is from Triad Online Training 08-10-07
when i saw this, it just gave thought to all the actual physical training equipment out there. and the ways the use weights, bands, cables, wheels. to transfer things around... perhaps a odd ball crane something like below image ?!?
below image is from FreeMotion Equipment|Body Tech Dallas, TX
this website gives a bunch of scaled models of train equipment. and just easier to give link to pages. vs trying to link to individual images...
Model Train Maintenance-of-Way Vehicles Page 3
Track Equipment Set - Kit - HO-Scale (dng100) Durango Model Train Maintenance-of-Way Vehicles
National Telescoping Boom Truck Body - Kit (unpainted metal) -- Fits Atlas Ford Truck, sold separately - HO-Scale (cfn7060) Custom-Finish Model Train Maintenance-of-Way Vehicles
Maintenance-of-Way (MOW) / Work Train Equipment (Unpainted Metal Kit) -- Kershaw RCH 100 Mobile Wrecking Crane w/Decals - HO-Scale (cfn7030) Custom-Finish Model Train Maintenance-of-Way Vehicles
had to special this crane out. due to to keeping the boom, dipper, and (bucket i guess) all extremely low to the ground and a long reach...
below image is from Maintenance-of-Way (MOW) / Work Train Equipment (Unpainted Metal Kit) -- Swingmaster Speed Swing Model 181 - HO-Scale (cfn7007) Custom-Finish Model Train Maintenance-of-Way Vehicles
one last thought is the mini excavators. the backhoe on them, could be considered a crane i suppose.
all i have for now... posting before i loose entire post....
*rubs chin* it needs to be stated one more time, to get it stuck into my head. unlike typical trains on tracks were there is massive engines pulling everything behind them. for the STB (side train box) tractor, the engines need to be split up across the entire length of the STB. main purpose is to spread out weight across all tires. provide backup with multi engines. reduce require massive size electrical wires and hyd hoses/pipes over entire length by supplying what is needed electrical and hyd power by a near by power source...
hhmmss...
the "engine section" shown in previous posts. really is not setting well with me.
current implements that fold out to 20 to 60 feet width normally have a massive structural support to support weight in transport weight, and then able to handle forces when implement is folded out...
the STB. would be just using the same extra massive structural support and re-designing it. to work with the STB. hhmmmsss....
how deep would someone want to till the old stalks and stems from last crop into the ground. so next crop could be planted? thinking of out of box, of completely different way to till / plant field crops....
if STB could pull a roll over scrapper. or box blade, or 3pt hitch dirt scoop... could you move the dirt onto the STB. do what ever with it. and then drop it back down...
quick note: when ya google images, and one of your own diagrams show up, you just gotta wonder...
before i posting more pictures found from google...
why not make a circus act out of each section... not a laughing matter either...
with the wheels being able to do 360 spins. and all the latest techno out there... have each section have a wheel module on each end. and have the links between each section disconnect, and have each section do a 180 degree spin. and then each section reconnects. *calls up government* for military laser guided missiles, and gets a discount for the laser guidance system. to place on each end of a section... to make things easy to align up and all computer...
barrow stuff from the mail sorting industry, paint a special markings on each end of implement, let camera pickup up on it. and guide the links between each section as computer turns and moves the wheels per section.
not really liking this idea, way to many things could go wrong more so on uneven ground, and more to the point ground that could be wet, rutted, while other sections hard as a rock. farmer would be having a tow truck on side of field paying by the hour.....
folding 3pt hitch cat 1 / cat 2 / cat 3ish setups... shows more of the bare bones of folding...
= ORTHMAN MFG. - FENTON REPAIR
think perhaps 2 rows of discs, some chisles, all in a narrow width setup. and then attached to a backhoe/crane. and instead of bucket = implement, and there just multi of these going down entire length of STB.
below picture is from V-shape hydraulic folding disc harrows RCHV
good amount of other pictures. the kinda double train caught my eye. and overlap of wheels in the center.
below image is from Valtra Ants Tractor by Lighthaus | Tuvie
the cab really caught me off guard. reminds me of a carnival ride. how it rotates around and up... hhmmss... and then entire machine can lift up higher giving more ground clearance. different..
below image is from Marauder Dozer by Jon Pope | Tuvie
just closed the page, and caught picture at the very last moment. never really thought about "angling" the wheels and tread on them. hhmmsss.... conveyer belt as tracks... na.... angle wheels ya... wider diameter but less physical height... ok maybe just a quick impulse thought...
below image is from UVO : Urban Vehicular Ovalon by Alexei Mikhailov for 2021 | Tuvie
instead of some future vehicle. turn the passenger area into a hydrostatic pump or electrical wheel motors?
below image from 40 Years From Now, We Might Drive 2F2 Electric Vehicle | Tuvie
ok i had to look just looked odd ball in thumb nail. something different that hyd cylinders... *shrugs*
below image is from Redesign Forklift Truck For Better Lifting and Maneuverability | Tuvie
looking at different crane possibilities, and saw this boom pole thumb and that HA!
below image is from Tractors and Farm Equipment
been thinking about folding up.. but this takes things i a new level!
but what about "roll over implements" you have ramps that let ya drive front or rear wheels right over a "finishing mower" on a lawn mower. to attach / unattach mower. why not let STB drive right over implements and then attach up to them... ok maybe not but *shrugs*
Uploaded with ImageShack.us
do chisels, bottom plows, discs, and like really need to be on rear side of vehicle and be pulled? or can they be pushed? push stuff on one side, and pull stuff on the other side.... for single pass doings?!?
below image is from Road Drag can be pushed or pulled by truck or tractor., Paul Wever Construction Equ
not able to get picture directly. different way perhaps to move implements side to side?!?
Strange dual boom drill
seems like a lot of motion and time to get implements swapped from one side to the other side.... as in minutes...
i am not sure what would be best for any given farmer. there are so many "shapes" and dimensions of fields. and what to do to make best use of the STB.... as in were to turn and were when to rotate implements to other side and scoot down the field how ever long the STB is and start going back down the field vs doing a long 180 degree turn....
when to split STB up into 2 or more sections. to do ends of fields and like.
i would imagine.... if 2 cabs (one on each end) a farmer in each one... on them much longer setups. one person keeping eye on direction, while another keeping on eye implements and gauges / cameras... *shrugs*... just do not know...and would down to individual field / farmer / and what would make the most use of it all...
perhaps main implement is on one side. and just a counter weight implement is on the other side... if needed...
then again if just going with implement on one side and not wanting to due 180 turns to get implement on other side. it would most likely make the entire frame work weight much, much less... that alone may be something...
back to drawing board to see what else comes up...
i am use to soy beans, corn, hay.... figure i better get into other things to see what the required....
came across a video. that does exactly what i am thinking about...
approx 3:00 or coupe seconds afterwards. it shows a wheel spining 180 degrees. though for STB tractor i would want it to do 360.
video from... T3
i never really thought about it... and that is wheel spacing... or rather "how wide" the wheels are compared to the crop rows.... in previous diagrams for wheel modules. i had 1.5 feet width wheel, and 2 of them side by side for of total of 3 feet plus the shaft coming down..... but... that might be a tad extreme for row widths... so.... needing to come up with a way... to make the 360 joint down to the wheel kinda of a universal swap out... form dual wheels. to single wheels were there are 4 wheels in a single line that can do 360 turns. to... a 2 tracks under the wheel module...
perhaps going with larger diameter wheels and at same time swapping out things from 360 joint down to the tire. to handle larger diameter wheels. hhmmmss... larger diameter wheels means longer links between sections as well perhaps.. as well as a change in gearing or changing out hydrostatic transmissions or electrical motors that runs wheels... of course if you change all that around the torque and RPMs are going to change possibly not having a beefy enough gear box... awe heck... if you want larger diameter wheels you would need completely different wheel modules... and longer links between sections possibly... all the implements would also change. in order to bridge gap around the wheel modules... yikes... entire new STB and implements for it would have to be made, just for larger diameter wheels...
so question is... can 2 feet diameter tires work for all the tasks out there? and for different tasks the frame work going between each wheel module would need to be raised up... most likely. just to make STB universal... across multi things... it would almost place engines either on top of wheel modules, or frame work just at the tops of of the tires with engines setting on the frame work... perhaps engines setting in between the frame work to help "lower" how high the engines stick up... that might work out nicely.
one last diagram for the night... the cable suspension bridge implement... :confused2:boggen new tractor idea102.png
feel sorry for anyone trying to follow this thread. i keep jumping back and forth randomly it would most likely seem. just going with ideas as they come up.
been thinking about "brakes" wet brakes, to drum, to disc. and then mechanical linkage, oil, or air brakes.
reading some on "train brakes" were the air pressure build up in a storage tank per cargo car is what pulls things apart and frees up brakes, and if air pressure gets to low, the brakes automatically apply. since air higher air pressure is what keeps the brakes from being used.
i like the idea of air brakes. but perhaps using it as a "fail safe" still rely on hyd oil to operate brakes. but when something fails. air brakes would automatically engage.
i like idea of "wet brakes" vs drum or disc the on STB. over drum and disc brakes. due to i could see drums and disc brakes like a car or truck might have, getting completely submerged and plugged up with water to mud to other. that may keep them form working.
what still has me though.... is i want to be able to have some sort of mechanical link. or something between tow bar / tongue between 2 sections of the STB. and to the wheels. so if computer / electrical goes out for what ever reason. every section turns into like a grain wagon that has 2 axles, and the front axle is what determines which way the wagon goes via pulling unit in front of it. but for this occurs the rear axle on wagon i would think needs to be locked into a certain direction.
this linkage per last diagram in last post. is what i am having problems with... and that is determining which direction wheel is spinning, and how many degrees the 360 joint is rotated at. and then how to guide or let the wheels lock at pre determined doing rotation in the 360 joint...
*duh* just been speaking about air brakes. to physical stop the wheels from spinning. why not some sort of wet brakes on the 360 joint it self.... and if electrical or hyd oil goes down, or air pressure goes down. the 360 joint will end up free spinning. but as soon as it rotates just enough. BAM oil pressure goes low, air pressure goes low, electrical servo is out. and the wet brakes on 360 slam shut.
TO above: the wheels will have there own wet brakes, and then the 360 joint will have its own wet brakes as well. both brakes would get applied, if a common air line that connects between all sections the entire length of the STB. if the air pressure in this air line got to low. both brakes would get applied. as a fail safe to stop the STB in its tracks...
the wet brakes on the 360 joint. needs to not automatically directly apply the wet brakes, to keep 360 joint from free spinning. but rather when the 360 joint is in correct degree of rotation !?!?
but how to get the wheels to fail safe in a given direction... if farmer/driver flips a switch to turn from field mode into transport mode. perhaps it adjust how the 360 joint goes into fail safe mode, if electrical and/or hyd oil goes out. and when in field mode, the fail safe does something different?
i realize above may seem odd. but when you goto brake, you just do not automatically come to a intimidate stop. it takes time for everything to slow down. each section of the STB needs to have its own brake setup for each set of wheel/s and each 360 joint. to help reduce how long it takes for everything to come to a stop.
i could see scenario of say just coming out of a field and something happened (something sliced a hyd line letting hyd oil leak. and you are on the road in transport mode when hyd oil goes low, perhaps causing short in electrical as well. and entire STB is just free wheeling down a steep hill. and only control farmer/driver has, is the steering wheel. and hope brakes start getting applied automatically on all sections of the STB. and to keep the sections from jumping over into on coming traffic or going into the ditch that is extremely deep.
i figure if all the sections would turn into 2 axle wagons (one front axle one rear axle, and the front axle is one that turns while rear axles stay in a fixed direction (360 joint is locked)). that it might help keep the STB tracking better and keep things from rolling over into on coming traffic or down into a ditch. when something did happen. and keep things tracking just long enough to get the STB to come to a complete stop.
ok what about this....
the farmer/driver has to physical flip a switch. between forward and reverse. when switching to transport mode. and all 360 joints have to keep rotating until all 360 joints get lined up. once lined up. the (switch) adjusted a "air pressure valve" that defaults to "fail safe" on every other wheel module. to set each section "rear axle" (refering to grain wagon with a front and rear axle). located in that given direction... while letting all the other wheel modules (every other ones) 360 joint be controlled by direction tow bar is being pointed / pulled.
the only way to adjust between forward and reverse, is via the switch in the cab. and when flipping switch it redos everything of how the fail safe gets applied... OUCH... that would mean, any time farmer/driver wants to go in another direction in transport mode, in order for fail safe to work. the "cab" would physically need to move to the other side of the STB. i suppose in field this would be a large pain in the rear. or would it?!?
arghs... brain fried... to many odds/ends. and jumping back and forth on different things, and everything has gone from general overview, and getting down into the more detailed doings...
past brain fried. and to many ideas and need to get some structure to this.
1. how would the STB operate in a field
1.1 how would STB operate on hills
1.2 how would STB make turns and ends of fields
2. how would STB train operate in "transport mode"
2.1 does STB require "cab" on the front of STB in which ever way it is going. and/or does a tow vehicle required (truck, special pull vehicle, 4 wheeler / SUV, car, semi) ?
2.2 what safe fail features are needed to keep STB from stearing out into on coming traffic or into another lane or into a ditch when something fails.
3. what are the dimensions of the STB
3.1 total length of STB
3.2 total length per section
3.3 total width in transport mode
3.4 total width in field mode.
4 how does STB brakes work
4.1 how does air backup work for braking
looks like a extremely long list i am gong to have to make. and then go back over list a few times to re-order things, or rather re-order as things change...
i guess i am past initial brain storming and ready to crack whip to actually getting into the niddy griddy details.
i guess i will quote this post as ideas come to me / time allows for diagrams...
index...
i guess i will quote this post as ideas come to me / time allows for diagrams... will attempt to "bold" what is in the post. and put a star symbol by things that were updated.
index...
*1.1 how would STB operate on hills
*1.2 how would STB make turns and ends of fields
*2.2 what safe fail features are needed to keep STB from stearing out into on coming traffic or into another lane or into a ditch when something fails.
*3.1 total length of STB
*3.2 total length per section
*3.3 total width in transport mode
*3.4 total width in field mode.
below diagram. really will not be any different that current age tractors and implements. and diagram was suppose to be for something else, till i realized it really does not matter... beyond the STB computer will need to take into effect hills and valleys. and move sections as needed to contend with hills and valleys...
2.2 what safe fail features are needed to keep STB from steering out into on coming traffic or into another lane or into a ditch when something fails.
when STB is placed into transport mode. what ever end of a section will be rear end in the direction of travel. needs to be able to lock those rear wheel modules. per section. at same time disconnect hyd hoses or electricity going to the 360 joint motor.
i am not sure if i would rely on some sort of disc / drum / or even wet brakes. to hold the 360 joint in place for these rear wheel modules. and would prefer to see some sort of rod drop through both top and bottom portions of the 360 joint. or some sort of rod that meshes with the gear that spins the 360 joint. to keep it from rotating. if a brake were to slip, just even a tiny bit, it could cause a given section to want to wobble back and forth between the ditch and the other lane.
thought for locking pin or locking lever to lock the 360 joint from spinning
some images i found on google. to help get better idea of what a wagon train might be.
below image is from ASA 90th Anniversary
4 good images with higher quailty images.
44-Series Grain Train Wagons - Brent Grain Handling Equipment
honestly unsure about. i would imagine it will be completely dependent on how tight the links / tow bar between sections are. and how much slop there is within those linkages. the more slop and more likely when ya goto break, first section ok, second section has some slop and you get like a whip lash effect (like someone just rear ended you at the stop light), third section does the same thing, so on and so forth. granted it is assumed all sections are breaking correctly but road conditions such as a gravel road, or wet surface could cause a major problem.
example all the sections before stop good but the last few sections are on wet ice. and just begin slamming into everything. due to unable to get enough traction compared to all other sections and sections begin slamming and jack knifing...
MPH (miles per hour) slower you go quicker it is to come to a complete stop. but still *shrugs*
3.2 total length per section just looking at laws for US, and came across a wikipedia notation for other countries that dealt with land trains or road trains. it would seem 63 feet is max for a trailer for a semi.
thinking about it. trying to drive anything to long. would cause a huge turn at the rear. even if the STB used AWD (all wheel drive) and AWS (all wheel steering) you would still be limited in total length per section. if you ever had to come to a regular intersection and dealing with road widths, without driving into ditches to get onto the cross road...
going to say 40 to 60 feet length per section, that is counting any sort of links between sections and rear of the section (direction of travel) when STB is in transport mode.
total width in field mode, i would imagine could be unlimited. and only limited by field size and how many sections you have...
revisting tires / tracks for the STB
came across the following site. gives a lot of pictures of tires to tracked vehicles.
Special Offroad Vehicles
some pictures that i found on above site...
it almost looks like both set of tracks could have a 360 joint placed on them. (front and back tracks)
nice long bus on 2 sets of tracks... awe!! i could see a STB! but instead of a bus some engines and implements folded up on top!
hhmmsss it might be able to have all sets of tires have a 360 joint on them. but man large diameter tires... and the height just to reach top of the flat bed....
gave idea of possible what the linkage might look like between 2 sections of the STB. but not sure.. looks way to short of distance hhmmss..
got to thinking about amusement park rides more specifically teacups
google -> amusement park rides teacups
below image is from Tea Cup Rides 3D Highlights
and then planetary gears
google -> planetary gears
Planetary Gear Set - YouTube
Ravigneaux compound planetary gear set - YouTube
then started thinking back at different track and/or wheel combinations...
to the last diagram...
perhaps a large "circle" frame work that operated under principles of a planetary gear setup. to both allow the wheels to turn 360 degrees. but also to run a drive axle down to each wheel.
when looking back at previous diagram/s
it would still be possible to get 8 tires and possibly reduce the dead man circle
the problems is "row crop" spacing. if you wanted to run STB in field without driving over the crops... and then individual turning of wheels (360 joint rotation), different RPMs for different wheels and different torque for different wheels..
the vertical drill bit tiller... :confused2::rolleyes: aka the "class 3 TORNADO maker"
EDIT:
hurricanes = water
tornadoes = wind
volcanoes = earth
calling it the "class 3 volcano maker" fits better as dirt erupts out the center.
implements.
generic and then fold up disc with space savings for transport.
all in one pass thoughts... *shrugs*
it has been bugging me the last couple days. of how to turn turn the wheels via tow bar / linkage between 2 sections of the STB. and finally GOT IT!
was looking at articulated tractors, to equilateral triangles with 3 cylinders. to rods and bars that pushed and pulled, to some sort of gearing all tied in... finally went and looked at grain wagons one last time. and hit it...
since the wheels on STB wheel modules can move back and forth to distribute weight, or extend out both sides to act like "out riggers" on a backhoe. everything virtually would quickly fail. or a link would need constant adjustments. no way to use some sort of expansion / contraction joints. any sort of wheels or levers would end up wobbling...
with double acting cylinders. i get a backup if one hose cracks/brakes /leaks fluid. and when is all is good both hoses per set of cylinders. will more likely not see as much pressure going through them. and hopefully pressure would be divided by half under normal operations. on fail safe side though. each of the 4 hoses will have to handle total max pressure that might be applied to rotate a wheel. and keep the wheel from freely rotating.
another thing, it also works in with keeping wheels nice and straight for the other side of the tow bar. for fail safe mode. or at least it could work in as long as things were well thought out.
linkages between 2 sections of the STB (side train box) tractor...
just not seeing it all work like wanted yet...
been on a war path for "regular train couplers" more so more modern up to date couplers. with electrical / hyd / air connections, besides the physical mechanical connection. and have it done automatically for connections.
and still not really liking what i see to an extent.
best so far i have seen is...
train coupler 4s versions. or 3 versions?
also like the "bull nose" vs over the what looks like to hands interlocked at the fingers (no thumb)
saw a rare couple videos, of couplers folding away up under the front panel. and then manually pulled out, then locked in, for when needing to connect to something else.
*rubs chin* the ends look small enough, but that is not saying much. without knowing actual dimensions.
everything seemed heavy, but done in a way that would overload a farmer that had some muscle.
reading through history of braking for trains. *long and dull* and thinking of what could be used as breaking setup for the STB. along with how it would drive in Transport mode. would each section power itself, or would there be a main front end, pulling and steering left to each individual sections? or would it by dynamic all the way. were engines would turn on/off wheels would rotate as needed, or power would goto certain wheels causing them power through a turn and perhaps slightly breaking on another wheel...
in field mode everything would be completely dynamic and left up to the computer for most part to control everything and keep things in line. leaving the farmer/driver to just operate speed on each of the far ends. of the STB. with manual override if needed for certain sections withing the STB that the computer just does not know what to do.
i am tempted to put some sort of small iddy bitty air compressor in each wheel module. and small air tank. so if electrical fails, compressed air will push what ever is needed to lock the brakes up. and only after air pressure is back up to a given PSI does the air brakes come off. and rest is left up to dynamically controlled electronics, with hydraulic oil operating what ever needs to apply the brakes, and how much to apply the brakes.
*rubs chin* i suppose a hydraulic accumulator might work. instead of air compressor / air tank. but how would you provide a "manual over ride" with say a basket ball or bicycle air pump. to release brakes if need be. to get a section back to the farm or a shop to get worked on...
really an air compressor can be fairly small. A/C in trucks to cars. is not all that big. and just runs off the belt, that the fan runs off of for the engine.... it is not like the wheel modules will have a cab or like. in that i would imagine a fairly easy swap out from an A/C pump to air compressor head would work.
ughs, air dryer... along with removal of water form the system....plus air tank. though i would imagine it would be a fairly small air tank. not directly known how high a air braking system would need. i doubt it would be high. so far seeing pressures form 75 to 120 PSI.
getting more over whelmed the more fail safe / valving that happens...
pictures / links i found in googling...
goes over electrical over pneumatic brakes on trains
Electro-Pneumatic Brakes
more on electrical type of brakes on trains.
ECP Brakes
glossary fairly long for train braking terms. with details
Railway Technical Web Pages - Home Page
more doings on brakes... explanation quiz / answers, rhymes and reasons.
North American Freight Train Brakes
good amount of other info on this coupler type i think this was a page that had video of the coupler in action
below image is from safety | MAX FAQs
tons of wire connections, but i would imagine half to 2/3rds of all the little dots are backup electrical connections. then again i may be wrong. the pipe going into the electrical connector does not look that big to carry that many wires for all those connections..
this one might of been link for the video of coupler connector in action.
Type 4 woes, June 18th evening rush hour | MAX FAQs
not a fan of the 4s coupler and all the manual connections...
really trying to avoid the multi connections between sections.
below image is from... Design Details of Railways, Railroads and Metros
trainweb.org history of things. and progression of old to what seems current or a few years off not really sure how current.
Coupling, Handing and UNDMs
it got me to thinking of how a STB (side train box) tractor would go down the road... or rather how it would work in transport mode. but with each section having powered wheels.... not sure if it really applies or not. perhaps fail safe? just not sure.
http://www.trainweb.org/tubeprune/Train Formation Diagrams.htm
loos to be a 350 page PDF file. for a old train / cars full specs and details.
http://www.aptastandards.com/portals/0/press_pdfs/association of american railroads.pdf
below links i have not went through atleast i do not think i have. found links from this page...
Transportation Safety Board | Home
Advanced Railway Research Center
Association of American Railroads
Canadian National
Canadian Pacific Railway
Health and Safety Executive (U.K.)
Institute of Railway Studies
International Railway Safety Conference
Railway Technology
The Railway Association of Canada
Transportation Technology Center, Association of American Railroads
VIA Rail Canada
tow bar / linkages between sections...
i just do not see a standard ball / hitch / receiver that you see on trucks and bumper pull like trailers. they can handle a good amount of weight. but the trailer hitch always has to come down onto top of the ball. the over all setup does not really give freedom to place any sort of automatic hooks of electrical connections, hyd connections etc...
the same thing goes for fifth wheel and pin tail hitches, i never came across any sort of "automatic" connections for extra things besides the physical connection that locks things into place. and you still need to get out and connect wire harnesses, and like.
quick hitches and like for implements for tractors are not all that great. all they do is the physical connection. and driver/farmer still needs to hook stuff up. i did come across a quick hitch from CAT for an excavator. that was hyd. for hooking / unhooking different attachments for an excavator (buckets, jaws, etc...) but i am just not fully seeing it happen. for linkages between sections of the STB.
going back over train couplers.... it would seem i have narrowed it down to.... scharfenberg coupler for trains.
if i am reading things correctly. there is no need to do a "latch test" you drive forward to connect 2 cars together of a train. and things should latch. to test if it did latch. you put the train/cars in reverse. and the car just hooked up to. still should have brakes locked up. if nothing moves your good to go. though that may still be wanted..
another issue is "chains" i am not sure if they would be needed or not with the scharfenberg coupler. with ball / hitch / receivers for bumper pull like trailers. ya gotta X chains below things.
other issue is, how much can a linkage hinge in degrees (left / right -90 +90, up / down -90 +90, rotate 0 to 360 degrees) and when "stops" are put in place or built into the design of the linkage. how much should they physical stop the motion of (left/right, up/down, rotate).
other issues is the actual automatic connections. for STB. you will be physically driving through dust, water, mud, water, snow, ice, heavy winds. and these automatic connections need to handle this. perhaps some sort spring loaded setups, kinda like quick coupler hyd hoses on rear of many tractors. and then some sort of "0-ring" like gasket seal for electrical wire harness connections.
the other issue, is physical weight of the tow bar / linkages / couplers between sections. i would imagine they will be heavy enough. and having a swivel jack with a caster wheel. will not but that functional, and would require some additional "pry bars" to move things around. more so when jacks have been seating on dirt and have sunk down into the ground. ((not really wanting to carry around a pallet full of concrete blocks, just to set jacks down on so the jacks do not sink down into the dirt.))
another issue and it goes back to limiting how much the linkages hinge / rotate in degrees... is driving down hills and stopping. and then sections of the STB begin to creep down (slop within the linkages / couplers) to a point were a section tries to ride up onto of another section.
another issue is "rolling over" one section wheel module may hit a large bump. forcing this section to roll over the large bump / rock. do other nearby sections allow for this within the linkages / couplers.
for dealing with electrical, hyd oil, pressurized air. i need to look more into the "robotic" tools / machinery. used in various manufacturing plants. for quickly changing between one tool end, to another tool end. perhaps they might offer a better automatic connection and automatic unhooking of things...
picutres / links
GOOD PICTURES OF VARIOUS COUPLERS FOR TRAINS!
Voith | Scharfenberg Couplers
flipping image gallery descent amount of good pictures of couplers for trains.
Railway coupler Picture Gallery - Photo Gallery - Images
Dellner Couplers' automatic coupler for OSC, Australia. - Image - Railway Technology
tightlock. still a tad confused, if tightlock is just a slight mod of the scharfenberg coupler or not
Patent US2214036 - AUTOMATIC TIGHT-LOCK COUPLER - Google Patents
in my wildest dreams, i never thought i would digging into all these extra stuff... i thought i was golden the very first post i made of this thread :laughing: that long went bye bye :shocked:
with above said, i am on hold up for everything else, on the STB. until the linkages / couplers / tow bar get figured out between each section.
to figure out actual dimensions and spacing of things. little bit longer linkages between sections means everything else needs to be adjusted a good amount...
there is also issue, of needing to some how easily attach a ball hitch / receiver, or pin tail hitch setup to things. so if need be a section can be towed behind a regular truck. along with issue of just physically tossing some chains on a section. to pull the bloody thing out of a muddy situation were it sunk down deep into the mud.
other issue, is being able to hook a implement on the short ends, were all this other stuff is going on for couplers and like. ((this one just kicked me in the rear))
*rubs chin* do i make the short ends "modular" sort of a universal quick hitch doing. to accept the various things. or do i attempt to get something that meets majority of all needs....
trying to draw some diagrams. of how a tow bar / linkage/s / couplers might move between sections...
and my mom, was just asking about, if i knew were rest of a old toy train set was, due to she found some tracks, that might go with it... when she was going through some boxes...
told her to just toss them in a box and i would toss them into the storage room here. but i might go looking for the train set. and use the holes that the pups have made, as a testing ground for some pictures...
i think i got, for the linkages between sections. though the smaller triangle is bothering me some. at moment i would actually have to see the rotation of things. to perhaps state a better design than the small triangle and collapsible pipes.
from one idea to the next idea.... not really giving up on current setup... for "wheel modules" (see below diagram)
but when going back through how implements would lift up to transport position. with above layout. i thought about a swing set....
get me some large beefy 4 to 5 diameter tires. get some transport only tires, and get me some engines. that all hang from a single large heavy duty pipe...
well 2 pipes... wait and see... will get me a machine that can transform at will, i tell ya!
as for the wheel modules. i am having hard time seeing implements folded up. that and i am wasting 10 feet per end of each section. and getting a tad frustrated... though i know i should put more effort into seeing how i could get implements to fold up. correctly... i am sure it can be done. but at what expense... (cost, weight, complexity, etc...)
MAHAHAHA! oh ya i needed that!
time for some pictures of FIELD SPRINKLERS!
below image is from Stock Photograph of Scenic Landscape Photograph Of Irrigation Sprinkler In Field In Montana USA. Located Outside Ghost Town Of Nevada City. - World of Stock
below image is from Sprinklers Watering Field | Royalty-Free Images | Photos.com
below image is from sprinklers, field, saturated, grainy - inspiring picture on Favim.com
OH YA! getting them AG tires going... not 2 but 3!
below image is from Irrigation Sprinklers In A Farm Field (Canada) Stock Photo 101918944 : Shutterstock
below image is from Irrigation Sprinklers In A Peanut Field Stock Photo 99294635 : Shutterstock
time for some SWING SETS
below image is from Swing sets recalled due to fall hazard - WKOW 27: Madison, WI Breaking News, Weather and Sports
alright we got a swing able double seater...
below image is from 6 Station Backyard Swing Set Would Be An Enjoyable Place For Your Kids | Plioz
Alright! we got a cab in the middle with emergency slides, double bench swing at the end, for some good old fuel, some gold old TIRE SWINGS :drool:, we have a gain auger or conveyer belt at the end to get the crop into wagons...
below image is from Harper's Buildings - Warsaw, VA
so lets turn these field sprinklers and swing sets in to a monster! of a machine :licking: :D
Warning extremely long diagram. you will need to scroll to see entire set of diagrams.
