New Tractor and Flail Mower
   / New Tractor and Flail Mower
Re: New Tractor and Flail Mower-Photos!
An orange tractor purchase would have solved the color coordination issue. Land Pride did offer a beige color option, perhaps not now that they are kubota owned??
I looked at Kubota seriously and really wanted to like the orange tractors. There is a dealer not too far away that is good to deal with. I've bought implements from him before. However, after a couple of test drives I just didn't feel as comfortable in the Kubota. The cab seemed a bit cramped, I'm 6'-4" and 250, and the controls felt a little awkward compared to my old New Holland TC-45D. The Case cab is roomier and the controls are fairly similar to the old NH. I probably could have adjusted to the Kubota controls after some use, but the Case was just easier. I also preferred the emission control system design on the Case compared to the Kubota.
My old Land Pride implements were beige, but after LP was bought out by Kubota orange seems to be the color of choice. A beige color if available at all seems to be limited. At any rate for what I wanted orange seemed to be all the dealer could source. Vic
   / New Tractor and Flail Mower #12
I had to go slower with my 7' flail than my 5' rotary on my L3200, but covered the same acres per hour more or less. What was explained to me & makes a lot of sense is mulching. Flails re-cut material a lot more & do a better job mulching. But all that re-cutting takes power. I like the superior finish quality & mulching action, so it's worth it to me.
Yes but your cutting 5 ft compared to seven hook up a seven ft rotary mower and see how your tractor handles it
Adjusted the cutting height of the LP FM2584 flail mower today. Cutting height can be adjusted from 0" to 6" in one inch increments by raising or lowering the rear roller. As delivered it was set at 1" which resulted in excessive scalping, the skid plates digging furrows and a nice mud pack on the inside of the mower housing. Here is a shot of from the rear with the access door open. It isn't necessary to open the access to adjust the cutting height, I wanted a better look at the internals of the mower. The rotor and Y blades are shown.
The mower was raised and supported on jack-stands. Shown here is the left side roller adjustment plate in the original 1" position. The right side is a mirror image.
The plate is adjusted by removing the uppermost large bolt and pivoting on the one on the left side of the plate. The LP manual suggests lowering the mower to the supporting surface to the approximate height desired and using a pry bar to raise the roller assembly to final height. I chose to leave the mower on the jack-stands and raise the roller with a Hi-Lift jack under the rear skid plates. I decided to raise the cutting height 2" from the original position for a total of 3" for another test run. Shown here is the roller in the new position.
Another test run was made. No more scalping, furrows or mud slinging! I plan on leaving the cutting height at 3" until later this Summer when the turf grasses (mostly Bermuda here) are actively growing, Then I'll raise the height a bit more. Later, Vic
   / New Tractor and Flail Mower #14
Very nice. I run my 90" 918h behind my Massey 1652 HST which has around 40'ish PTO HP. What made you upgrade to the new flail? Was it just a matter of getting new equipment?
And congrats on the new tractor, I'll be interested to hear how you feel about the CVT transmission compared to your hydrostat.
I also like to make recommendation to you. Get a hydraulic top link for that tractor!!! They're not that expensive and they literally are a night-and-day change to what you've been dealing with on almost every rear Implement that you'll be using. With the flail, you can change the cutting height on the fly simply by extending or retracting your top link. Basically you change the angle of attack of the flail, and it's an instantaneous change from the seat of your machine while you're driving.
Here's some frozen Cattails that I mowed down this winter when the ground was firm enough. By removing the rear trash door of the flail and pulling in the drawbar to tilt the back up, on the Fly, I was able to back into the worst areas and run the machine almost like a forestry Mulcher until I knocked it down a bit. (Note, this wasn't my 918h, actually borrowed my buddies, as I managed to break the mounting 3-point bracket on mine a week prior and didn't get a chance to take it apart and reweld it... His flail doesn't have the rear rolling drum, so it's easier to back into brush like this)
   / New Tractor and Flail Mower #15
Yuk! New Land Pride / Kubota orange isn't a great color match for a red tractor. It'll just have to do though.
I have never understood the obsession with matching tractor and implement colors. What's wrong with the color of the implement showing off its brand? Are people not proud of the brands of implement they bought, or what?
TSO: Nice job on the cattails! The 918H flails mow really well. The buyer that bought the old NH TC-45D wanted a package deal since he had no tractor or implements. I sold him everything: Tractor, flail mower, grading scraper, box blade, 3-point sprayer, quick hitch, tiller, etc. The NH 918H was still mowing great after 16 years. As I got older, I'm 82, I no longer had the hand and arm strength to mount the mower and stab the drive line on the PTO stub shaft by myself. I'm hoping the new tractor and mower with quick hitch will be a somewhat easier, particularly mounting the PTO shaft.
I'm starting to get used to CVT operation. I still find myself shifting my right foot trying to the find the other pedal to reverse directions at times. Sixteen years of habit are hard to break overnight! The steering column mounted lever is becoming easier to remember after some use.
I've looked at the hydraulic top links in the past. Seem to be very useful. May try one later.
TerryR: I'm not really obsessed with matching tractor and implement colors. I ran the NH TC-45D tractor for 16 years and never had any blue implements. Actually I had beige, orange and red implements. When I say "match" I don't mean necessarily the same colors, just those that don't clash! If I wasn't "proud" of the implement brands I bought, I'd of bought something different! :D. Vic
   / New Tractor and Flail Mower #17
I noticed that you didn't seem too concerned, but I see lots of comments here about getting implements in matching colors which has always seemed odd to me. So my comment was aimed more at my long-standing puzzlement. Your comment just brought it to mind again.
   / New Tractor and Flail Mower #18
Someone on this forum a while back mentioned a trick for hooking up PTO shafts- loop a bungy cord around the top link and the shaft. Find the right size and strength so it holds the shaft level with the PTO stub on the tractor.
   / New Tractor and Flail Mower #19
I just got a green Peruzzo flail to go behind my Orange Kubota. Asked the dealer if there were other color options, but there weren't. Was concerned enough to ask, but not enough to do much about it.
Thanks, good tip! I've used a somewhat similar method in the past using a ratchet strap instead of a bungy cord to support the shaft. My problem was turning the mower PTO drive shaft against the inertia of the mower gear box and rotor to align the splines with the tractor PTO shaft. The TC-45D PTO shaft was locked in place when the PTO was not engaged and would not turn. The Case PTO shaft has some movement when not engaged allowing the splines to be aligned without turning the mower shaft. I haven't had to dismount/remount the mower yet, so time will tell. Vic
Case Ih 2388 Combine (A50514)
Case Ih 2388...
2021 Delta Redirective Crash Cushion 75000 (A49461)
2021 Delta...
2016 Ford F-150 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
Chevrolet C8500 Flat Bed with a Moffet Kit (A52128)
Chevrolet C8500...
2014 Dodge 5500 4X4 Bucket Truck (A52128)
2014 Dodge 5500...
