new TPS with powered trailer
/ new TPS with powered trailer #1
domo
ROMANIA , East Europe
Labinprogres , Super Special Green 10hp
Hi everyone
I'm thinking to buy a 10 HP, TPS tractor ( it is a Lombardini clone ) with a powered trailer . It comes with 12 inch wheels with agri tyres , and ground clearance is kinda short . Any ideas if it can handle a really rough terrain ? . (The dealer says it can handle any road no matter how difficult ) .. transport(2).jpg
Here is a youtube video with the tractor in action YouTube - Macos & Hall . I never tried one of these tractors for real , so that's why I still worry about ground clearance and problems with differential . The dealer says it has lockable differential but I think that is only for front wheels . The trailer doesn't have a lockable differential so in case of a slipping wheel you can lose traction and if you are going uphill on a steep slope with a loaded trailer you can get in trouble ( correct me if I'm wrong ) .
Finally bought one , two days ago . I got also a couple of attachments ( 32 inch rotary cultivator and 42 inch sickle bar mower ) . It has electric start :licking: , 4 speeds forward and 2 speeds reverse with lockable differential . I used it to cut grass ( 2 acres ) and I tried the trailer too . There is lots of torque and power to haul almost one ton easily . There are two PTO's ( upper and lower ) but you use only the lower one with the trailer , rotavator or mower. The upper PTO (smaller ) is for powering a water pump . So far I'm happy with the machine but I haven't tested the rotavator yet .
/ new TPS with powered trailer #5
Sounds like a nice machine, I'd like to have a sickle for my BCS. Would like to see some pictures of all that machinery, is the rotary cultivator the same as what we call a rotary tiller?
/ new TPS with powered trailer #6
Yes pics, pics!
/ new TPS with powered trailer #7
Ok...long time since I have been here. But if youエre intretsted in pics of 2wheel tractors with driven trailers, you should join www.einachserforum.de in the pictures (Bilder) section You will find a lot of 2wheelers with driven trailers
Guess this combinations are more common in europe then in the US.
the second pic shows a Gutbrod (Bucher CH) with driven trailer from the 50th. The pics have been taken from a bookside.
/ new TPS with powered trailer #8
Great to have you back Mac,, hows things across the pond?
/ new TPS with powered trailer #9
Hi JS,
fine so far. we have purchased a Honda F 700 walkbehind an Agria 1600 tiller, a Eicher tractor with 72 hp and a Welger baler Type AP 45,
Winter has come early this Year, lot of snow. Lot of work to care for the animals, the hens and heifers we own.
Snow means, that we canエt go for work. Fine for doing repair in the shop..but ...no money.
Oversize load ??? Is there such thing ? Guess not ! Check this out . I will try to post a video too .
‪TPS Labinprogres uphill oversize load‬‏ - YouTube .
There's a video showing my tractor going uphill with quite some load , hauling lumber ( some of 20 foot ). Trick was to convert the trailer to a flatbed by removing front and rear gates including seat , and reversing the handlebars . Balancing the weight was a challenge and managed by placing the shorter beams upfront . Securing the cargo was done with heavy duty nylon straps .
2012 Toyota Tundra SR5 Crew Cab Pickup Truck (A61568)
2012 Toyota Tundra...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
7102 (A61567)
7102 (A61567)
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
1999 Ford F-150 4x4 Pickup Truck (A61568)
1999 Ford F-150...
TORO TIMECUTTER SS3200 ZERO TURN LAWNMOWER (A62131)
TORO TIMECUTTER...
