new top link: how to install the leverage rod used to adjust the length
   / new top link: how to install the leverage rod used to adjust the length #11
I have had this same problem. What keeps it coming out once you bang it through?
Some distortion of the hole is elastic so it snaps back a little. You would be able to hammer it back thru the same spot with a smaller hammer shoud you ever need to remove.
I tried again this morning with a 5# short-handled sledge hammer. The leverage rod went through just fine. Took about two licks on the first hole, which had already been shaped some from my prior efforts, and three licks on the pass-through second hole. Then curiosity drove me to see if I could easily pull the rod back out, since I wanted to know if it might fall out easily from vibration. I could not, even when I lined up the little tabs with the grooves they had made passing through the hole. I think I could pull the rod out if I had the little tabs lined up precisely and pulled really hard, but I didn't want to do that. I think the rod is in to stay. Thanks to you prior posters for the advice.
2024 Bintelli ActivEV Pulse Electric Cart (A59231)
2024 Bintelli...
Trailmobile Van Trailer (A56438)
Trailmobile Van...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
Towable Dewatering Pump (A59228)
Towable Dewatering...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
