new top link: how to install the leverage rod used to adjust the length
   / new top link: how to install the leverage rod used to adjust the length #1
rbtjr
Piedmont in NC
Kubota MX5800
I had to get a longer top link due to installing the Pat's easy change quick-hitch device. I bought it at TSC. The top link came with the rod that runs through the center of the top link, perpendicular to the top link, that you use to turn the top-link turnbuckle screws to adjust the length of the top link. This rod is about 10" long or so. Due to this rod having some little flanges on each end, it will not pass through the hole in the center of the top link that the rod must pass through in order to fulfill its function. So, I wondered, how do I install this rod? I did a TBN search and saw one thread in which someone else asked the same question. The answers were that you have to beat this rod through the center hole in the top link outer body with a hammer. I hit it a few licks, and I will do this if I have to. I was wondering if anyone else came up with a different way to do this?
Thanks in advance. fyi, I am thinking about buying a 10" cap screw that will fit through the center hole in the top link, putting a locktite nut on the cap screw, and ending up with the same functionality without having to beat the rod through with a hammer.
   / new top link: how to install the leverage rod used to adjust the length #2
i beat it through. months ago. still works good.
   / new top link: how to install the leverage rod used to adjust the length #3
Yup, SOP. Bang it through with a hammer. No point in over-engineering. I seat mine with one swing of a 3lb drilling hammer. The little raised "flanges" on the turning rod cut right through the soft metal of the turnbuckle, then keep it from sliding out once it's punched through.
//greg//
//greg//
That's what I thought. So, I tried the regular claw hammer a few licks. No progress. I then tried a light sledge hammer a few licks. Again, no progress. I must be babying it.
   / new top link: how to install the leverage rod used to adjust the length #5
Wail on it!
One sharp blow with a 2lb ball peen and mine was all set.
   / new top link: how to install the leverage rod used to adjust the length #6
A claw hammer is not for hitting hard steel like this rod, use a ball pein or hand sledge. I drove mine in with w 20 oz ball pein. Just hitnit hard and steady, it will take a few hits but it will go. As was said hit hard once to seat and get it started, then maintain pressuore to hold in place with one hand while hitting it hard. Took all of 2 minutes to drive it through both sides.
   / new top link: how to install the leverage rod used to adjust the length #7
OR...you could grind off the little tabs on the rod and gently thread it through the holes. Then weld a couple of tacks where the tabs were so the rod can't slip out. Be sure to paint the welded end.
BUT...I just use a drilling hammer also. Give it a healthy whack or two.
   / new top link: how to install the leverage rod used to adjust the length #8
I did this too.
   / new top link: how to install the leverage rod used to adjust the length #9
I have had this same problem. What keeps it coming out once you bang it through?
   / new top link: how to install the leverage rod used to adjust the length #10
LAY THE LINK ON A HARD SURFACE. Also, lube pin flanges with a moly anti sieze. Hold the pin with rubber in Vise Grips so youre confident your fingers are safe. Give it a firm whack with a 3#+ hammer.
larry
pressure washer, and trailer (A56859)
pressure washer...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
Mower deck storage axles
Mower deck storage...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
