new top link: how to install the leverage rod used to adjust the length
   / new top link: how to install the leverage rod used to adjust the length #11
I have had this same problem. What keeps it coming out once you bang it through?
Some distortion of the hole is elastic so it snaps back a little. You would be able to hammer it back thru the same spot with a smaller hammer shoud you ever need to remove.
I tried again this morning with a 5# short-handled sledge hammer. The leverage rod went through just fine. Took about two licks on the first hole, which had already been shaped some from my prior efforts, and three licks on the pass-through second hole. Then curiosity drove me to see if I could easily pull the rod back out, since I wanted to know if it might fall out easily from vibration. I could not, even when I lined up the little tabs with the grooves they had made passing through the hole. I think I could pull the rod out if I had the little tabs lined up precisely and pulled really hard, but I didn't want to do that. I think the rod is in to stay. Thanks to you prior posters for the advice.
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
PARTS ONLY - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - 2023...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56438)
Michelin CARGOXBIB...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
