New to trailering
/ New to trailering #1
jacobweaver32
Bronze Member
NE Ohio
MF 1533
I want to trailer a MF 1533 with FEL & Backhoe (~4200lbs), the trailer is a 16ft car hauler w/ 15" wheels (1600lbs) w/ two 5k lb axels. The trailer is rated at 7k lbs load. It has 10" or 12" (can't remember which) trailer brakes. This will not be used for commerical use nor work for hire.
I want to pull it with a 2007 Sport Trac V8 4x4. The tow capacity of this truck is 6990lbs; max payload is 1350lbs (I believe this number is over the wheels) I am not sure what the hitch weight capacity is.
I know most will say get a REAL truck... but I dont need an full size truck for anything more then possibly pulling around my tractor once in a while. So please comment on whether this is a suitable setup... or what changes I should make.
Also, I am in Ohio and know nothing about owning or regestering a trailer for hauling. Am I thought I just had to get a license plate for it and I was good to go.... am I missing something obvious here? Do I need to insure the trailer as well?
Thanks for any help!
/ New to trailering #2
It seems to me that you will be right at capacity. You would also need to consider your weight and fuel as well as your tractor. Are your tires loaded?
Will you be going down any hills? I would say if you are going up and down hills (definitely not mountains) then I would not do it.
I am sure others will comment as well but these are JMO.
I would say a 1/2 ton truck would be better suited towards your situation.
Here in Colorado I license and insure my trailers.
But then there were those people towing their Air streams with their Caddys with HUGE mirrors too.
/ New to trailering
Tractor holds ~10 gallons of fuel (add 50lbs) Tires are not loaded. Although may add weights to them depending out how it performs...
I won't be doing any hilling, mostly flat around this part of Ohio (West of Youngstown).
I know a 1/2 ton would be best but the vehicle will be for my wife... and we are thinking about having a kid or two in the next couple of years... so a 4 door with great safety features is important to us.
thanks for your thoughts!
/ New to trailering #4
If your Sport Trac has a trailer hitch it should have the weight capacity listed on it and if it has a tow rating of 6990 it should have a hitch rated for at least that amount.
Your tractor (4200#) and trailer (1600#) total 5800# which leaves you an 1190# margin of safety. Just make sure you have at least a 7500# rated ball to tow it with and brakes on the trailer wired to a brake controller in the truck cab. I don't see a problem for ocassional towing this package.
I don't know about Ohio but in my state trailers need to be registered for the rated weight cap. (yours would be 7000#) then DMV issues a license plate. Trailer is covered by auto insurance when hooked to the tow vehicle. Your tractor is usually covered by homeowners insurance while on your property but may require additional insurance if off your property. Maybe an Ohio member can be more specific on regs. there. I hear some states don't required trailers to be registered but don't know if thats true or not.
/ New to trailering #5
My Ford tow guide says that an Explorer needs a class III/IV receiver to pull anything over 3500. I would say you will be OK towing locally once in a while. Just be aware of how much weight you got back there and plan ahead. Most car hauler I have seen had surge brakes but if not you will need a brake controller. I have no idea about Ohio laws. Here in Az it would be one time liftime license for the trailer you tell the DOT how much you want to carry and they charge you for that amount.
/ New to trailering #6
Here in Ohio, for non-commercial use, you just get a plate and go. The plate is priced by the weight of the empty trailer, not it's capacity. You will need to have the trailer weighed and then take the "official certified" weight slip to the DMV. Needless to say, remove as much from the trailer as possible before weighing, ie, no chains, ramps, spare tire etc.
Fortunately, Ohio hasn't joined the "charge 'em and license by capacity" philosophy that other states have adopted for non-commercial vehicles.
It's always best to check with your insurance agent before you start towing just to be sure.
/ New to trailering #7
IMO you should give some serious consideration to a weight distribution hitch which helps distribute the tongue weight of the trailer over both tow vehicle axles and some back to the trailer. It would greatly stabilize the rig from an up and down standpoint and also generally helps reduce or eliminate side to side sway. For good towing you need 10 - 12 % of the total trailer and cargo weight as tongue weight. With a 6,000 lb trailer weight you need a MINIMUM of 600 lbs to 720 lbs weight on the tongue, preferably closer to 800 lbs. - 850 lbs would be better. With that much weight that far behind the rear axle of a light duty truck you will likely get some hobby horse effect without a weight distribution hitch. They cost well under $500.00 for a good quality one such as an EZ Lift or Reese.
You will also need a good trailer brake controller installed on the truck unless the trailer has hydraulic surge brakes. I assume from your description you have brakes on all 4 wheels.
Since it sounds like you're a novice at this trailering thing you might want to get an experienced friend to help you sort this out and to take you on the road first with the empty then the loaded trailer.
An out of control trailer is one **** scary thing.
Good luck
/ New to trailering #8
A friend of mine loaded his sub-cut and loader onto the trailer and said it will be ok, I am only going a mile. In that mile he ended upside down in the ditch when something went wrong because of the way it was loaded on the trailer. If it is't safe don't drive it. The life you take may not be your own.
/ New to trailering #9
Take some time and read this http://www.fordvehicles.com/assets/pdf/towing/07RVsporttrac9-15.pdf
Double check the weights that you have listed. According to MF the shipping weight of just the tractor is ~3000# and you are quoting a total weight of 4200# (w/Loader and BH?) My Kioti CK20 weighs in around 4600# with the same equipment. Does the trailer actually weigh 1600#? The MSO for my 16' trailer says 1500# but based on numbers from hauling some gravel it is closer to 2000#. You still need to consider Tie downs (Chains and Binders), Weight Distributing Hitch (Required Per Ford), other equipment you may carry with you, and any weight in the vehicle in excess of 150#. (Minimum weight that most manufactures use for driver when figuring tow capacity).
There are plenty of 4dr 1/2 ton trucks out there that offer the same or better safety. Your biggest problem is getting out of your current vehicle without taking a major hit in depreciation.
Good Luck
Kurt
/ New to trailering #10
I like plenty of towing capacity. I was pretty well maxed out with our boat behind my 1/2 ton pickup for towing capacity and I hated it in the hills and wind. I was really working the engine and transmition over good. I felt as though I was not safe towing it. I decided to bite the bullet and buy a 3/4 ton and I have no regrets for doing so. When I would come down a hill and pick up speed if I got going to fast I could feel the back end of the truck start to sway. These were not big hills I live in Illinois.
/ New to trailering #12
I have a 1433, with FEL and some type of implement all the time on it. (almost exactly a 1533)
i have a 20' trailer (much nicer to move stuff around) bumper pull with 5200lb axles. (so it weighs more than your trailer)
A sport Trac is effectively an explorer.
there's no way i would pull this with an explorer.
No way.
1/2 ton truck/suburban/expedition minimum
/ New to trailering
Wow... thanks everyone... posts are very helpful, infact I dont know where to start. So I'll just start rambling.
Obviously, safety is very important to me, and I would hate to have the feeling of the swaying on hills.
I think there are alot of variables here because I don't really know how much the tractor will weight with the FEL and BH. Once I find this out I will be better off... maybe I can contact the manufacturers of these implements and find out their weight.
As far as the sport trac goes... I would definately get the class III/IV tow package with the weight distribution hitch. I don't think the concern is so much whether the truck CAN do it.... I think its a matter of whether at can be done safely.
I found some numbers on the weight of the 2007 Sport Trac - curb weight 4,793lbs & a max payload of 1,350lbs & width is 73.7".
Numbers on a 2007 F-150 are - curb weight 4,663lbs & max payload of 1,940 & width of the truck is 78.9".
Got these from: 2007 Ford F-150 Specifications & Data at Automobile Magazine
What do you think of this?? To me the only concern is the width; which translates to me as load control. Other then that I don't see much of a issue here.
Again, I'm a noob so let me know if I'm not making any sense...... it is just things that I don't have experience in I tend to go with man'f specs as my guideline.
/ New to trailering #14
you've read the other posts. Most folks will tell you to get a larger truck. Once you start towing a load that is over the weight of the tow vehicle, the game starts to get serious. You will have a 5000# tow vehicle and a 7000# trailer load. Really, that's not all that bad. BUT, you have to maintain the trailer brakes. Absolutely, get the weight distributing hitch and an anti-sway for the trailer, so it won't be wagging the truck.
The trailer will probably have electric brakes. That's ok, but they are manually adjusted. That means 2x a season you have to jack up the trailer, crawl under it and manually tighten the star adjuster down on each wheel. Not a big deal, but it is so often forgotten it ain't funny. Once a season you have to take the wheel off, remove the hub and grease the bearings. Again, it's not that big of a deal, but it gets forgotten a lot. Usually, you remember when the hub catches fire after the bearings melt down. If you aren't comfortable doing that, have it done at a tire or alignment place in the SPRING before you tow.
You will need to carry an extra trailer tire (and hub and bearing set if you are smart/paranoid). Make sure the truck and trailer have GOOD tires. For some reason, you only find yourself in panic situations on rain slick roads.
You can also search for how to load the equipment. You want 15% of the load on the hitch. 7000# load is 900# on the hitch. Measure bumper drop without using the weight distribution hitch to determine how much weight you are carrying. (Mfg specs on spring rates should be known.)
As a novice tow-er, buy professional grade chain and ratcheting binders. Expect to spend $200 or a bit more. If you buy good stuff, it's a life time purchase. Junk is seasonal...
jb
/ New to trailering
Thanks guys this is/was very enlighting.
Jake
/ New to trailering #16
I think you are getting the Whole Picture. One other thing that is important is wheelbase. A longer tow vehicle will be more stable as well as width.
Everyone has given very good advice as you would expect on TBN.
Happy trailering.:)
Shane
CFG NT18K (A60463)
CFG NT18K (A60463)
2022 John Deere 1025R (A53317)
2022 John Deere...
CFG QK20R (A60463)
CFG QK20R (A60463)
2006 BIG TEX 20 T/A GOOSENECK TRAILER (A60736)
2006 BIG TEX 20...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
AGT Industrial STSD10 QA (A60463)
AGT Industrial...
