Mowing New to Mowing & Brush Hogging Steep Slopes
   / New to Mowing & Brush Hogging Steep Slopes #21
SPYDERLK said:
Wow. Bummer! Is it full of hydro? My BX1500 [hydro] will climb til it loses traction on AGs in 4wd with diff locked. Thats around 45 degrees. If yours is filled to the correct level when it does that I think you have grounds for serious complaint. That is dangerous.
larry​
Yes, gear would be no problem. Mine had the correct oil level. The Dealer said that at that angle, the oil pickup could have been scavenging. Angled the other way, the oil pickup would have oil all around it and no problem.
   / New to Mowing & Brush Hogging Steep Slopes #22
SPYDERLK said:
It keeps the AGs pulling in the correct direction for high traction. If you have to back back up a soft wet hill with the ags facing wrong you can quickly get compromised.
larry​
So what if you have turfs, r-4?
I can see if you have no place to turn around. In that case you don't have much choice. Personally I wouldn't feel comfy backing down a steep slope. My tractor is light in the front, if I go straignt down I know it's not doing an end over end. :D
   / New to Mowing & Brush Hogging Steep Slopes #23
Light front is your problem there. Big tires on the down[high ground force] end gives better traction even with turfs.
larry​
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
FENCE PANELS (A58214)
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2012 FORD F-550 SUPER DUTY (A58214)
2012 FORD F-550...
