Mowing New to Mowing & Brush Hogging Steep Slopes
   / New to Mowing & Brush Hogging Steep Slopes #21
SPYDERLK said:
Wow. Bummer! Is it full of hydro? My BX1500 [hydro] will climb til it loses traction on AGs in 4wd with diff locked. Thats around 45 degrees. If yours is filled to the correct level when it does that I think you have grounds for serious complaint. That is dangerous.
larry​
Yes, gear would be no problem. Mine had the correct oil level. The Dealer said that at that angle, the oil pickup could have been scavenging. Angled the other way, the oil pickup would have oil all around it and no problem.
   / New to Mowing & Brush Hogging Steep Slopes #22
SPYDERLK said:
It keeps the AGs pulling in the correct direction for high traction. If you have to back back up a soft wet hill with the ags facing wrong you can quickly get compromised.
larry​
So what if you have turfs, r-4?
I can see if you have no place to turn around. In that case you don't have much choice. Personally I wouldn't feel comfy backing down a steep slope. My tractor is light in the front, if I go straignt down I know it's not doing an end over end. :D
   / New to Mowing & Brush Hogging Steep Slopes #23
Light front is your problem there. Big tires on the down[high ground force] end gives better traction even with turfs.
larry​
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
2019 Ford F550 Chassis (A55973)
2019 Ford F550...
2015 Infiniti QX60 SUV (A56859)
2015 Infiniti QX60...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56435)
PENDING SELLER...
