Mowing New to Mowing & Brush Hogging Steep Slopes
   / New to Mowing & Brush Hogging Steep Slopes
I used the advice from all of you and tried cutting one of my steeper slopes, about 20 degrees. I went forward; straight up and down in 4WD with loader as low as possible. Brush/ground was dry. I was using my Frontier RC1048 which did a nice job. Never felt unsecure; no pucker factor at all.
Uncut area in pictures has no room at bottom, and is wet due to a spring that seeps water most of the time.
Girl is my one of my daughters (5' tall).
   / New to Mowing & Brush Hogging Steep Slopes #12
Good photos - really can tell how steep it is!
I have some similar areas that I bush hog a couple times a year - once you do it once or twice, and get a good feeling of your machine on a certain slope, it feels better.
Glad you got it done safely.
   / New to Mowing & Brush Hogging Steep Slopes #13
The pics really do a good job of showing the slope. I'm not sure if it's too steep to cut sideways or not, but it doesn't seem to matter, you got it done!!!
I started out bush hogging my place, but now I have a finish mower and it's allot easier. The finish mower doesn't put any weight on the tractor, so I can handle side slopes even better then before. AND I can mow in wetter areas wtihout getting stuck. I still get stuck all the time, but that's because I push it and I'm not very smart. hahaha
Thanks for the pics,
Eddie
   / New to Mowing & Brush Hogging Steep Slopes #14
Good pics!
As far as the uncut area, I'd try backing down. I think that will work for you.
As far as the wet area...as long as you go slow (low range, 4WD), I think you'd be OK. As written in my first response, wet grass is slick. However, go slow enough so the worst case is a tow up slope (rather then a runaway slide). Might be worth giving it a try...
   / New to Mowing & Brush Hogging Steep Slopes #15
RoyJackson said:
Good pics!
backing down still seems real unnatural to me. still don't see what backing down will do for ya.
   / New to Mowing & Brush Hogging Steep Slopes #16
176
If you don't have a turnaround area at the bottom of the slope, it works quite well. I do it everytime I mow...but although my slope is steep (>20°), it's not long (maybe twice the length of the tractor/RFM combination) or too wide (60-70 feet). The most important thing is to go slow enough for an easy stop...going up is easy.
   / New to Mowing & Brush Hogging Steep Slopes #17
It keeps the AGs pulling in the correct direction for high traction. If you have to back back up a soft wet hill with the ags facing wrong you can quickly get compromised.
larry​
   / New to Mowing & Brush Hogging Steep Slopes #18
larry​
Backing down can be fine and easier to cut first with shallower slopes. But watch out with the degree of slope! As the slope approaches 30+ degrees, my 2520 looses hydro and I'm left with only the brakes. For the steep stuff, I will only go down forward now. The hydro stays intact and it can back up up hill better until the traction is lost.
   / New to Mowing & Brush Hogging Steep Slopes #19
Never had that problem with my gear tranny 790.
   / New to Mowing & Brush Hogging Steep Slopes #20
Wow. Bummer! Is it full of hydro? My BX1500 [hydro] will climb til it loses traction on AGs in 4wd with diff locked. Thats around 45 degrees. If yours is filled to the correct level when it does that I think you have grounds for serious complaint. That is dangerous.
larry​
Water Line Hose (A59076)
Water Line Hose...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
22' x 23' All Metal Garage (New/Unused) (A59225)
22' x 23' All...
