New to me TC29D cranks & won’t start
   / New to me TC29D cranks & won’t start
So I’m finally back life happens and I had to learn to rebuild our Polaris ranger front diff and axles. It services our small ranch and took priority.
To the tractor my thought was to test my gauge to known good diesel (only one we have is a kubota bx1800) got it disassembled to learn my deluxe tester kit doesn’t have the correct adapter for it… lovely
So tried to rent one. Only gas ones available anywhere I checked oriley autozone etc etc
So I went ahead and purchased a second one with the intent of keeping if necessary and returning for other tools if not.
Tested compression side by side gauges measured within 5 lbs pressure of one another…
   / New to me TC29D cranks & won’t start #102
No surprise. Shops would go out of business if they had to double purchase every test instrument.
To screening & checking engine oil
bought paint screens and cut apart old filter with pipe cutter
Oil and filter were very dirty but nothing out of ordinary in catch pan oil filter or paint screen… found a few chunks of orange paint type material in screen was the most significant…
A
Agreed but it was mentioned multiple times so I thought worth a try
   / New to me TC29D cranks & won’t start #105
The low compression, blow by and the sound of the way it cranks would be enough for me. After all the years working on engines I can tell low compression by the sound of the way it cranks.
Here’s a vid for visual and sound of engine cranking condition, battery etc this is no bat charger on glow plugs in and disabled & no fuel. More cranking in following videos below
Valve cover off rocker check videos be kind I’m a diesel novice doing my best lol
None seem too tight once I check at the right time of course
Here’s a vid of the way it cranks above
Opinions of experts please. Sounds fair to me what cranking
   / New to me TC29D cranks & won’t start #110
IMO we might could have sorted this out by now while OP is doing everything right so far. I also suggest that further tests of fuel delivery may bear out before shotgunning a new pump/parts and bucks if not needed.
btw, I'll be here 'til we get our guy up and running. Ask me later why I'm so fired up to do so. :)
Champion C80 B Motor Grader (A50322)
Champion C80 B...
2009 Chrysler Sebring (A50324)
2009 Chrysler...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A51242)
2016 JOHN DEERE...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
Tallman Water Pump (A50774)
Tallman Water Pump...
