3-Point Hitch New to me Kubota B2920 3pt question
   / New to me Kubota B2920 3pt question
See if they can give you the PN for the vertical lift link on your tractor, the non adjustable one for the the B26 is PN 32721-65270. If it matches then all the major components are the same.
I just meant to verify with them what all was included with the kit.
I attached a PDF with a bunch of part #'s etc for the B2920. I'm not sure if this is what you were looking for or not.
  • B2920-3Pt hitch.pdf
   / New to me Kubota B2920 3pt question #22
I used to own a 2920 and I upgraded my turnbuckles to the nice sliding telescoping ones you drop the pin in, Kubota puts on their top of the line tractors...L-Grand Series and to nicer B-series. I have since sold that tractor and put the original ones back on it and transferred these newer ones to my B3200 and have some setting on a shelf somewhere that came with the 3200. Give me 20% of the new price and I will pay the ship. Or if not and you bite the bullet for new get the telescoping ones I have.......so much easier to put the attachments on when you can slide the turnbuckles in and out.
Here is the old thread I used when I converted.
http://www.tractorbynet.com/forums/...92-b7800-b29xx-telescoping-stabilizers-2.html
and here was the shopping list I had from 2013
02174-50160 2 NUT, M16 0.71 $1.42
04011-50120 4 WASHER, PLAIN 0.13 $0.52
04015-60160 2 WASHER, PLAIN 0.32 $0.64
04512-60160 2 WASHER, SPRING 0.19 $0.38
05122-51235 2 PIN, JOINT 1.49 $2.98
05122-61245 2 PIN, JOINT 1.23 $2.46
05511-50425 4 PIN, SPLIT 0.13 $0.52
05515-61000 2 PIN, SNAP 0.45 $0.90
6C070-65310 2 BRACKET,STABILIZER 30.69 $61.38
6C070-65320 2 PIPE, STABILIZER 15.7 $31.40
6C070-65333 2 PLATE, STABILIZER 15.7 $31.40
6C070-65340 2 PIN,STABILIZER 2.6 $5.20
6C070-65350 2 BOLT, STABILIZER 2.6 $5.20
Good luck....With your project.
   / New to me Kubota B2920 3pt question #23
Those are the same diagrams I looked at and don't see the the vertical lift linkages shown.
   / New to me Kubota B2920 3pt question #25
Shipping might kill the saving but I found this on a quick search.
Kubota-B3941-Kit-Lynden-Washington-2138581
I actually emailed those guys earlier today and am awaiting a shipping quote. I still haven't confirmed if it will actually all fit or not. I hate to ship it across the country and not have it work out. I'm awaiting a follow up from a friend of mine who is an O.G. Kubota dealer. He's doing a little homework to see if the B26TLB kit will work....or at least get close enough that we can swap out just a few pieces.
I appreciate your response but I didn't quite understand it. Are you saying you have the B2920 3pt setup from your old tractor, or is what you posted the parts to make the telescoping arms work with the stock B2920 stuff.
   / New to me Kubota B2920 3pt question #28
The only part I haven't been able to confirm will interchange is the verticle lift links because they weren't listed on the parts diagrams I found. Everything else will interchange.
   / New to me Kubota B2920 3pt question #29
I only have the turnbuckle arms and the they are the same for a 2920 or the 3200 that mine are from. I has also saying that if you buy new.... get the telescoping ones and supplied the #'s. Sorry about the multi-thought post.
I removed the backhoe today to get a better look and this is what I found. Some of the parts are there. The pin and spacers on the bottom as well as the draw bar are there. I'm hoping maybe someone will be able to tell exactly what I need from the photo.
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
2010 Chevrolet Traverse SUV (A56859)
2010 Chevrolet...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
2017 Ford F-450 Service Truck w/ Liftgate (A56858)
2017 Ford F-450...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
