new to me 03 century 2535
   / new to me 03 century 2535
So i figured out my power steering!
Started working this morning moving dirt, heard a big pop and a shower of hydraulic fluid all over me lol. Blew a line right off at the steering wheel. After that notice a steady stream of fluid coming from the left side cylinder seal as well. Decided to pull all 4 lines and the rack to go get rebuilt. Had to drop the front axle to get the rack out. Too easy with a Ryobi 1/2 inch impact
   / new to me 03 century 2535 #73
Man, you are going to have one heck of a tractor when you're done! For cheap no less!
Hopefully! From what ive seen so far the previous owner did absolutely zero maintenance. So who know what else is next. I wish the front loader moved faster though. Has anyone put a higher flow pump on? Or even a newer model pump maybe? I think these flow 8.5 gpm but not sure.
Another note! Where the hell do you get headlights for these old things?
   / new to me 03 century 2535 #77
Glad to see you "found" the problem.
Sounds like you're going to be up and running soon. Congrats on getting the steering rack apart in the field in less than a day.
As far as headlights, do you need the whole light, or just a new bulb?
The only time I've needed one, it was just the bulb, and I was able to locate the replacement at my local Napa store.
This is the one for the factory cab work lights, but it was a "common" bulb they had on the shelf.
It won't be the same one you need for a headlight, but take your bulb into the store and they can match it up. That's what I did.
I will double check but when I looked, it looks like the old cars. The bulb is apart of the whole assembly glass and all. I will see if the plug part twist out.
   / new to me 03 century 2535 #79
even on the older models the bulb socket should twist out the back and allow you to change out just the bulb
2025 New/Unused LandHero 40 Gallon 2-Stage Air Compressor (A51573)
2025 New/Unused...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2121 (A51244)
2121 (A51244)
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
