new to forum, plus I have limited experience with tractors....
   / new to forum, plus I have limited experience with tractors....
I'm seriously considering a backhoe over a new tractor. I have land I plan to clear and the backhoe would come in handy to remove stumps and tree debree ect... I don't know much about them though. I'll have to do some research and ask questions on what to look for in buying a used backhoe... If any of you know what to look for in buying a used backhoe, I would be grateful for your input and wisdom. I see they have a few around here at some auctions ect...
Thanks
David
For 2,800lb logs, you'll need an FEL that can handle more like 3,500lbs at the pins (since the weight is farther forward than the pins, which lowers lifting capacity). Very few compact tractors get into that range, so you're probably looking more at Utility class tractors. FWD will definitely help with FEL work when you have that much weight out front, and you're probably going to need a decent size 3pt counterweight.
For what you're doing, it sounds like a true backhoe would do a better job...way more lifting capacity, and a lot more capable for digging stumps etc, and you can use your current tractor for stuff like brush hogging, etc.
   / new to forum, plus I have limited experience with tractors.... #12
I really don't care much for auctions as it seems what goes to auction is things that cant sell any where else. Some folks can ferret out a good deal now and then, but by and large the are for experts that know what they are looking at so they don't get ripped off.
Try Craigslist, local equipment dealers and even rental yards for your back hoe. You will be able to get on them operate them and check for leaks, loose pins etc. You likely wont find a used 580 back hoe less than $20K that doesn't have some wear in the pins. Slight looseness at the joints isn't that big a deal as long as it isn't excessive and nothing is broken or has cracks in the boom or other parts. Swing cylinders are notorious for leaking so check those closely along with all other hydraulic lines. You need a buddy to go with you to look for leaks etc while you operate or vice versa, two sets of eyes are always better than one. Check the transmission to make sure it shifts easily, pulls without slipping etc. Check it out in all ranges to make sure every gear works.
   / new to forum, plus I have limited experience with tractors.... #13
For a logging tractor the 5530 would be a good choice in my opinion...simple with brute strength. I looked into them myself when I was buying. You might also look into the Workmaster series by new holland....also simple and strong.If I had more land and was looking into purchasing a bigger tractor today for logging work I really like the 5e series deere with power shuttle. Pretty good bang for the buck. Power shuttle transmission sure makes log jockeying with the loader much easier.
Agree.
   / new to forum, plus I have limited experience with tractors.... #14
My 2008 Mahindra 5525 is a simple, rugged, heavy tractor (55 hp engine, 45 hp pto, 2WD, partially synchromeshed tranny 8F/2R, power steering, triple rear hydraulic remotes) with the ML250 FEL (6-ft wide bucket, 2950 lb lift at the pins to 10.5 ft height, skid steer quick attach option), weighs about 7000 lb with the FEL and loaded rear tires. Cost new: ~$19K. It compares to that 5530 you mentioned.
Good luck.
Good luck.
I'm really in between which way I should go... Backhoe vs tractor with FEL(maybe backhoe attachment)..... Buying the Mahindra 5530 with FEL and backhoe attachment new would give me a solid machine I could depend on. Buying a used backhoe could be a money pit to keep working. But, for the money the Mahindra with FEL and backhoe attachment would cost, I could maybe get a decent used backhoe and also a newer used tractor to replace my old ford that is weak and old.
Buying used equipment is a shot in the dark when you don't know much about them, which is my case. If I knew I could find a decent used backhoe I think I would go that route.. But I know nothing about them. Buying a used tractor is no problem, for I know enough about them.
I'm leaning towards getting the 5530 with FEL and possibly a backhoe attachment to go with it... I'll keep digging for info and contemplating on it until I'm blue in the face I guess....
   / new to forum, plus I have limited experience with tractors.... #16
Welcome from Wisconsin
   / new to forum, plus I have limited experience with tractors.... #17
i'm right there with you. looked at the workmaster and bought a 5055e. also looked at the mahindra 5530. the JD is been a great tractor. using forks i picked up a 30" by 8.5' oak log. it was the max i would pick up.
dad has a used case 580 E. got it for $6500 several years ago. it has been great. but the hydraulics can be expensive to repair. he has spent about 1500 in the past 5 years resealing some cylinders and replacing some hoses/fittings. the backhoe will not do s well in the woods as a smaller tractor, but you might not want to take a new tractor into the woods either
   / new to forum, plus I have limited experience with tractors.... #18
Hello all,
I have 80 acres mostly in timber. I also own a small manual sawmill that I have been using to cut timber off my land. I plan to build a new shop that will also be storage for lumber I cut, and new sheds for equipment with the lumber from my place.---------------------------------------------------------
What I want is a tractor with a front end loader. It needs to be able to handle heavy logs with either a pallet fork on the front or forks on the back to be able to load them on my sawmill. Plus it needs to be able to pick up heavy stacks of cut lumber to be moved to drying sheds.
research has told me that I'm better off with a 4x4. They run about $5k higher than a 2wd. Do I really need a 4wd? Yes ----
Any input is very much appreciated. I have even considered a backhoe/loader since I have a tractor...
What do you guys think I may need??? Something better than a tractor, a compact Telehandler! :thumbsup:
thanks,
Dave
I also have 80 acres, lots of trees, mostly too many Cedars. Most guys on TBN say they didn't know about my V417, so I will post again.
It is 6' wide, 6.5' high and 13' long. 4 wheel drive, 4 wheel steer, 2 wheel steer and crab steer. Tire size is 14x17.5. Top speed is 15.5 mph, drawbar pull is 7,000 pounds and it will lift over 5,000 pounds. Has a SSQA and Aux Hydraulics on the boom.
It will easily run a 7' brush hog.
Much better view of front forks or grapple, than from a tractor seat.
Will remove big trees faster than a backhoe, just push it over and pick it up.
Another tree pushover picture thread: http://www.tractorbynet.com/forums/...our-technique-removing-trees.html#post3356253
And it is UNSTUCTABLE!
Motion Imparied: http://www.tractorbynet.com/forums/...t/160568-compact-telehandler.html#post3526054
Compact Telehandler:
http://www.tractorbynet.com/forums/bobcat-construction-equipment/160568-compact-telehandler.html
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
(41) T-POSTS W/ (20) ROLLS OF BARBED WIRE (A54757)
(41) T-POSTS W/...
2025 Swict 72in Bucket Skid Steer Attachment (A55787)
2025 Swict 72in...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
FAKE (A52472)
FAKE (A52472)
