New TN 70 Owner
   / New TN 70 Owner #1
odarby
N Ridgeville, Ohio
Ford 1720 & NH TN70
Hello & Help - I need to change the hydraulic fluid on the TN 70 I recently bought. Can anyone help me with where the drain plugs are? I have been told there are 4 - I only see two
Thanks
   / New TN 70 Owner #2
well i own a tn70 great tractor i might add. as far as i know there are only 2 plugs one is under the trans and the other is in the back can't miss them the only plugs there. make sure you have a lage drain pan you will have around 11 gallons of fluid comming out. it takes 11.4 gallons to refill. the rear plug has a magnet to collect metal so pay close att and see whats on the magnet. what year is your tn70
   / New TN 70 Owner #3
one other thing you might consider putting a extra fuel filter in the line going to pump i took a pic of mine. these pumps are very expensive to fix or replace. DSC00483.jpg
   / New TN 70 Owner #4
Welcome to TractorByNet. -kid
   / New TN 70 Owner #5
Welcome to TBN:welcome: Fro Medina Oh
   / New TN 70 Owner #8
I have an 03 and believe I only have two trans plugs as well.
   / New TN 70 Owner #9
Welcome to TractorByNet!
I moved your thread to the New Holland Owning & Operating forum. :)
   / New TN 70 Owner #10
one other thing you might consider putting a extra fuel filter in the line going to pump i took a pic of mine. these pumps are very expensive to fix or replace.<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=317097"/>
What happened with your pump? I've not heard of anyone else having pump issues from bad fuel.
LMC G300JD LOT NUMBER 245 (A53084)
LMC G300JD LOT...
UNUSED FUTURE FT-P45 HYD BREAKER HAMMER (A51248)
UNUSED FUTURE...
WOODS DHS48N LOT NUMBER 75 (A53084)
WOODS DHS48N LOT...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2022 John Deere 8R 310 MFWD Tractor (A53342)
2022 John Deere 8R...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
