New TN 70 Owner
   / New TN 70 Owner #1
odarby
N Ridgeville, Ohio
Ford 1720 & NH TN70
Hello & Help - I need to change the hydraulic fluid on the TN 70 I recently bought. Can anyone help me with where the drain plugs are? I have been told there are 4 - I only see two
Thanks
   / New TN 70 Owner #2
well i own a tn70 great tractor i might add. as far as i know there are only 2 plugs one is under the trans and the other is in the back can't miss them the only plugs there. make sure you have a lage drain pan you will have around 11 gallons of fluid comming out. it takes 11.4 gallons to refill. the rear plug has a magnet to collect metal so pay close att and see whats on the magnet. what year is your tn70
   / New TN 70 Owner #3
one other thing you might consider putting a extra fuel filter in the line going to pump i took a pic of mine. these pumps are very expensive to fix or replace. DSC00483.jpg
   / New TN 70 Owner #4
Welcome to TractorByNet. -kid
   / New TN 70 Owner #5
Welcome to TBN:welcome: Fro Medina Oh
   / New TN 70 Owner #8
I have an 03 and believe I only have two trans plugs as well.
   / New TN 70 Owner #9
Welcome to TractorByNet!
I moved your thread to the New Holland Owning & Operating forum. :)
   / New TN 70 Owner #10
one other thing you might consider putting a extra fuel filter in the line going to pump i took a pic of mine. these pumps are very expensive to fix or replace.<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=317097"/>
What happened with your pump? I've not heard of anyone else having pump issues from bad fuel.
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
UNUSED FUTURE 14' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 14'...
