New Thumb
/ New Thumb #11
If you are modifying to make it act more like a grapple, then why not purchase a grapple? Then you could allow the grapple to remain stationary as if it were a thumb or retract and close as a grapple... just wondering.
Because I already have a set of pallet forks and I use them a lot. If I had a thumb on the forks it would do everything I need it to do at a reasonable price. I don't need a $1000 - $2000 grapple sitting in the yard just to move some brush piles once in a while. My forks with a thumb on them will do most anything a grapple will do! :)
/ New Thumb #12
Very nice George2615. I installed "The Thumb" on my R3039 last year also but had to modify the bucket to in order to get the correct angle.
I like the idea of mounting the thumb on pallet forks as well. Did you buy an extra mounting plate or just swap the entire unit out when changing over?
/ New Thumb
I'm in the same situation. I already had a bucket and forks. Didn't want to spend 1-2K on a grapple bucket or grapple forks to have them sit around for the few times a year I'd be using them. I only needed to add a grapple thumb. I guess I'm cheap. The mods in question would apply to the thumb I added or even if I had purchased regular grapple forks or a grapple bucket. The jaw doesn't open far enough with such a short stroke cylinder. I'm happy with the way mine came out.
/ New Thumb
Ball Ground, I did buy the extra mount plate. It would be easy to swap the entire unit by unbolting the 4 - 5/8" bolts but about 25-30 lbs. heavier. With the extra plate I don't need any tools to swap it and it's a little lighter than with the base plate.
/ New Thumb #15
Your not cheap Goerge, just efficient!
/ New Thumb #16
Was not intending to call anyone cheap or inefficient. I do not have any idea as to what the cost of the thumb would be in relation to a grapple, or grapple bucket. If it works with your modifications and the cost to add a different ram to get more action (open and close) is minimal, then I can understand. I will be moving some treetops and limbs from my property after I have the timber cut. I was thinking a grapple bucket would be my best option. You both have valid opinions and options for using a thumb.
/ New Thumb
I'm the one who said I'm cheap.
1) I can not justify spending 1-2K on a grapple bucket for the few number of times a year I'll need it. Same would apply for the price of grapple forks.
2) The thumb I bought with extra base plate cost me about $600. ($650 counting the angle steel I bought)
3) I can swap the thumb from forks to bucket in a minute or two giving me the choice of grapple forks or grapple bucket for 1/4 of the price of 2 separate grapples.
/ New Thumb #18
I too have a recently installed Thumb on my Kubota M4700. Cost me approx $700 total, including running wet lines from rear remotes and having my neighbor do the metal work. I figure that's anywhere from $500 - $1500 less expensive than a stand alone grapple, depending on quality, etc. FWIW, the Thumb is built like a shickbrithouse.
The Thumb actually offers some advantages over a stand along grapple. For one, you can don't have to switch implements whenever you want to switch between bucket and grapple. For another, the spread between the fully open thumb (I have the 36" model) and the bucket lip is 5-feet, a wider opening than most stand alone grapples. This has been huge for me, since I move round bales regularly. I'm not certain it'd be so simple with a stand alone grapple.
I'm sure a dedicated brush grapple would be better for moving brush. But I can still move huge piles of brush, logs, round bales, and just about anything I can think of with the Thumb for half (or less) of the price and no changing implements.
/ New Thumb #19
Thanks for all the comments... now I need to decide if I still intend to go grapple bucket, or thumb!!!
2012 Honda Civic Sedan (A59231)
2012 Honda Civic...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2018 Toro Groundsmaster 7200 72in Zero Turn Commercial Mower (A59228)
2018 Toro...
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
Yanmar YT359 (A53317)
