New Thumb
/ New Thumb #1
George2615
Super Member
Central Square, NY
LS XR3037HC
Finished installing my thumb.
See all the pics in the Attachments thread post Added a thumb.
/ New Thumb #2
Very cool...looks super handy. Did you add the reflective strips to your loader arms? That's a really good idea I'm going to have to copy. R,
/ New Thumb
Yes I added the tape to this tractor and my previous one. Makes it easier to see. I have reflective tape on the side of the cab below the back side windows too. Picked it up fairly cheap at HF. I use it on all my trailers too. I like to be seen and not hurt. You can't have enough lights and reflective tape.
/ New Thumb #4
Very cool George! I just showed it to my Wife, she said "GET IT". Hope you don't mind but could you answer a few questions? Looks like the 36" ? Does it go compleatly verticle when retracted? And if you could describe how much travel from retracted to fully open? Thanks :thumbsup:
/ New Thumb #5
Whoops, disregard, seen other thread now:eek:
/ New Thumb
Look at the pics I posted. They show the thumb fully up and down on both the forks and bucket as installed. Hard to get more movement with a cylinder that only has a 6" stroke. The problem with a 6" stroke is you can't get the thumb fully vertical and close enough to touch the bucket or forks. I did get the 36" mainly for use on the forks. I am going to change the thumb mount angle on the bucket so it will close more.
/ New Thumb #7
Would it be feasible to mount a longer stroke cylinder, and would it work?
/ New Thumb
No, a longer cylinder would make it close more but open less. The only way to make it open and close more would be to change the pin position where the cylinder mounts. I am going to look at that tomorrow to see if I can drill holes lower on the bucket thumb mount bracket to move the cyl. down.
/ New Thumb #10
If you are modifying to make it act more like a grapple, then why not purchase a grapple? Then you could allow the grapple to remain stationary as if it were a thumb or retract and close as a grapple... just wondering.
/ New Thumb #11
Because I already have a set of pallet forks and I use them a lot. If I had a thumb on the forks it would do everything I need it to do at a reasonable price. I don't need a $1000 - $2000 grapple sitting in the yard just to move some brush piles once in a while. My forks with a thumb on them will do most anything a grapple will do! :)
/ New Thumb #12
Very nice George2615. I installed "The Thumb" on my R3039 last year also but had to modify the bucket to in order to get the correct angle.
I like the idea of mounting the thumb on pallet forks as well. Did you buy an extra mounting plate or just swap the entire unit out when changing over?
/ New Thumb
I'm in the same situation. I already had a bucket and forks. Didn't want to spend 1-2K on a grapple bucket or grapple forks to have them sit around for the few times a year I'd be using them. I only needed to add a grapple thumb. I guess I'm cheap. The mods in question would apply to the thumb I added or even if I had purchased regular grapple forks or a grapple bucket. The jaw doesn't open far enough with such a short stroke cylinder. I'm happy with the way mine came out.
/ New Thumb
Ball Ground, I did buy the extra mount plate. It would be easy to swap the entire unit by unbolting the 4 - 5/8" bolts but about 25-30 lbs. heavier. With the extra plate I don't need any tools to swap it and it's a little lighter than with the base plate.
/ New Thumb #15
Your not cheap Goerge, just efficient!
/ New Thumb #16
Was not intending to call anyone cheap or inefficient. I do not have any idea as to what the cost of the thumb would be in relation to a grapple, or grapple bucket. If it works with your modifications and the cost to add a different ram to get more action (open and close) is minimal, then I can understand. I will be moving some treetops and limbs from my property after I have the timber cut. I was thinking a grapple bucket would be my best option. You both have valid opinions and options for using a thumb.
/ New Thumb
I'm the one who said I'm cheap.
1) I can not justify spending 1-2K on a grapple bucket for the few number of times a year I'll need it. Same would apply for the price of grapple forks.
2) The thumb I bought with extra base plate cost me about $600. ($650 counting the angle steel I bought)
3) I can swap the thumb from forks to bucket in a minute or two giving me the choice of grapple forks or grapple bucket for 1/4 of the price of 2 separate grapples.
/ New Thumb #18
I too have a recently installed Thumb on my Kubota M4700. Cost me approx $700 total, including running wet lines from rear remotes and having my neighbor do the metal work. I figure that's anywhere from $500 - $1500 less expensive than a stand alone grapple, depending on quality, etc. FWIW, the Thumb is built like a shickbrithouse.
The Thumb actually offers some advantages over a stand along grapple. For one, you can don't have to switch implements whenever you want to switch between bucket and grapple. For another, the spread between the fully open thumb (I have the 36" model) and the bucket lip is 5-feet, a wider opening than most stand alone grapples. This has been huge for me, since I move round bales regularly. I'm not certain it'd be so simple with a stand alone grapple.
I'm sure a dedicated brush grapple would be better for moving brush. But I can still move huge piles of brush, logs, round bales, and just about anything I can think of with the Thumb for half (or less) of the price and no changing implements.
/ New Thumb #19
Thanks for all the comments... now I need to decide if I still intend to go grapple bucket, or thumb!!!
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2011 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2011 Caterpillar...
2020 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 KENWORTH T680...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2014 Kenworth T370 21ft. Flatbed Truck (A64194)
2014 Kenworth T370...
