New Thumb Build
/ New Thumb Build
The way your thumb pins are secured is not enough. Those presto pins will fly off in no time! Best to use 5/16" bolts, with nylon lock nuts.
If you don't know the rated pressure of your third function, be carefull when putting the new replacement cylinder. Its rated PSI may be too low for the third function pressure delivery. You may want to undo the cylinder lines, install a pressure guage, and plug the end of the line. Run a test and see for yourself. Industrial equipment do run at higher pressures.:):2cents:
Your right about the presto pins but I was so excited to use the thumb. I will bolt after I get the pressures right.
/ New Thumb Build
Thumbs looks great, you don't appreciate it until you have to use a machine without one. Did you send your build to the Princess Auto projects site?
No I didn't know about the Princess Auto project site. I'll have to check it out. Thanks
/ New Thumb Build #23
No relief yet,I'm going to pm firemanmike69 to see if he knows if my machine already has relief install. I do know the thumb and curl cylinders have the same pressure because they fight each other.
I can bet you it does,;) but at what pressure is what you need to find out.
/ New Thumb Build
Found out today relief valves are 250 a piece. I need 2 if I don't already have them installed. I'll get a pressure reading tomorrow.
/ New Thumb Build
So I do have relief valves on the excavator,that's good. The pressure was 3000psi we lowered it to 1800,that's good! The bad is the thumb ram creeps down quite fast,15 seconds or so. What did I do wrong?
/ New Thumb Build #26
Does it basically just fall down ? Look to see if the hammer valve is shut. If it's open it will let the oil on that side of the ram mostly bypass the valve and return to tank
To isolate the cylinder from the rest of the machine close the valves on the stick and see if the problem persists
/ New Thumb Build
/ New Thumb Build #28
I don't know, but maybe that relief pressure of 1800 is too low and its relieving.
That does sound like it would be a low relief setting for a thumb.
/ New Thumb Build #29
I'm guessing from your video that there is something wrong inside the valve that operates the thumb. Or there is an electrically operated valve somewhere that's not working properly.
/ New Thumb Build #30
Maybe the machine has a motor valve to fit hydraulic breakers and attachments that use hydraulic motors, that can cause this problem.
/ New Thumb Build
I have my own theory,the 2 relief valves are not exactly the same pressure 1700 ish and 1800ish. I want to balance the 2 with the machine running and watching the reaction of the thumb. I think???
/ New Thumb Build #32
I dont think that the thumb has enough weight to open the relief valve
/ New Thumb Build #33
I'd try the machine running while I slowly raised the setting on the relief and see if it stops. Then check the pressure
/ New Thumb Build #34
Looked in the service manual today here's the layout of the valve and the functions
And if you're not reading the pressure directly at the attachment here's where you can read them on the pump
/ New Thumb Build #35
Did it start when you adjusted the relief valves. If not, it sounds like your valve for the thumb has a 'motor spool' in it, rather than the usual type of spool.
/ New Thumb Build
I had no time today. I hope tomorrow.
The Takeuchi said they adjust their thumbs to 1800 psi,it seems a bit low to me??
Also the thumb only started this creeping after I adjusted the relief valves.
/ New Thumb Build
No problem sorry it took me so long to get back to you
Ok,so today I adjusted one of the relief valves until the ram stopped lowering. That worked but there is not much clamping pressure. I was told 1800 psi was the number to set the thumb at. Is this at an idle? Thanks.
/ New Thumb Build #40
I would like to see a picture of the relief valve. I am pretty sure mine has a cross over relief valve near the base of the main boom. Its quite a large unit but I have purchased cross over relief valves from Princess auto for other projects and they where not $250. PA has a 10GPM Poppet style for 99 bucks.
Case TV380 (A62177)
Case TV380 (A62177)
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
Lot 602 (A62613)
Lot 602 (A62613)
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
