New Stihl MS290 starting
/ New Stihl MS290 starting #1
TNTractor1
Jackson, TN
2011 JD2520
I am a new 290 owner... my first chainsaw. I have used it a couple of times, but lately can't get it started. I am following the manual as far as i can tell. With the 1st or second pull it starts but dies quickly and then you can forget about it... just sounds flooded. Seems like a great saw, but I wish I knew the secret to not flood it. Thanks
/ New Stihl MS290 starting #2
You choke it and pull the cord. After it "pops" or fires once then take the choke off and pull again. It should start. Pulling the cord a second time with the choke in will cause flooding. Make sure u pull the cord quickly but smoothly as the manual says.
Let us know how it works out.
/ New Stihl MS290 starting #3
Just like above. But like to add to it.
Move to choke pull till here cough or pop couple pulls usually. Then slide off choke up 1 notch to fast idle start. Pull it should start in a couple pulls and should be running fast idle with chain turning. Blip throttle and it should go to normal idle.
I usually leave run on fast idle for a few seconds to warm up on a cold natured saw.
Once warm just go to first notch down from off position to start.
/ New Stihl MS290 starting #4
Have you pulled the plug to see if it is wet? If it is not wet than it is not flooded and maybe not getting any fuel. I have an older Husky 371 that if it sits will not get fuel and I need to pour a little into the plug hole to get it started.
Thanks for all the advice. I will let you know how it goes.
Followed your advice and I got it started. I think before I was making too many pulls with the cold choke on. Thanks again
/ New Stihl MS290 starting #7
Glad it works! Have fun with your new saw!
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
43023 (A59228)
43023 (A59228)
2019 CATERPILLAR 259D3 SKID STEER (A60429)
2019 CATERPILLAR...
2017 BX2680 Sub Compact Utility Tractor (A61306)
2017 BX2680 Sub...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
UNUSED FUTURE BD98-98" HYD BACKHOE DIGGER (A60432)
UNUSED FUTURE...
