New sickle bar attachment and wiring
/ New sickle bar attachment and wiring #1
PowerTracManiac
Central, Virginia
Power Trac 1460
Just bought a sickle bar attachment for my PT1460. Need to tame the brush coming in from the sides of my driveway. The attachment comes with a 12V electric switch that operates a hydraulic valve that diverts the hydraulic flow from the sickle bar cutter motor to the lifting cylinder. This way you have one set of hoses from the machine to the attachment to control both available functions on the attachment (sickle motor cutting or lifting angle of the sickle arm from the cylinder). Both at the same time is not possible with this configuration. I am going to tap into the tractor 12 volt supply to get power for the switch and run it to the cab so I can switch the hydraulic flow from sickle mode to cylinder mode from the cab. I think I am just going to tap into the front light wire for the 12V power since it is loose right at my dash. I found a wiring diagram online for a 1845 and I will post separately.
/ New sickle bar attachment and wiring #2
Why not just use the Q/A ports to control the cylinder and add an extra pair of small diameter hoses?
I did that for a 3rd party power broom that wanted to do the same thing. I didn't want an extra switch and 12V out in front, but that might just be me.
All the best,
Peter
TU for the good idea.
Would need to make up more hoses and not ready to do that at this time.
/ New sickle bar attachment and wiring #4
That hose looks long enough to get to your QA points. But if it is not in the cards, I just opened the top plate and accessed the wiring underneath. I had a bonus switch on my dash and that now is my controller for my electric sprayer.
/ New sickle bar attachment and wiring #5
That's basically what I did, except I put a 12V outlet tucked up under the dash for when I need my sprayer. It stays nice and dry up there.
All the best, Peter
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
2013 JLG G6-42A TELESCOPIC FORKLIFT (A60429)
2013 JLG G6-42A...
2011 Toro Workman HD Gas Utility Cart (A59228)
2011 Toro Workman...
John Deere Z994R (A60462)
John Deere Z994R...
2008 CATERPILLAR 277C SKID STEER (A60429)
2008 CATERPILLAR...
