New shop build, beginning stages with questions
   / New shop build, beginning stages with questions
I'm with you so far, I only had so big of a piece of steel on hand... it's spanning 3 joists (4x4's so a little sturdier in some ways) and lag bolted at the front and has threaded rod at the rear through the joists and in the center it's through the top plate of the wall at the junction.
I'm going to run with it for now but will likely add a support going back further in the middle, might be just an eye bolt and cable...
   / New shop build, beginning stages with questions #282
Any chance of running a metal pipe up through the center of the hoist, maybe up to 7' high, and then cable from the top end back to your outside wall post as a top anchor?
That's the type of thing that's been running through my mind lately and would be functionally cleaner than lower mounted cables... even if I put a 2x6 across the angular supports (probably 5' above the crane) to catch the top of a post welded to the top of the pivot it would help a lot... I'm not planning on testing any limits of the thing, the heaviest engine block I plan on dragging up there for now is only about 500 pounds and I'm not in a rush on that... for the smaller bulky things to get out of my way I'm not worried at all up to 300 pounds or so.
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2016 CATERPILLAR 962M LOADER (A51242)
2016 CATERPILLAR...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
