New shop build, beginning stages with questions
   / New shop build, beginning stages with questions
As of yesterday the roof is complete other than the trim around the fascia and whatever the side ones are called... which means I still have to run a screw every 9" on the fascia boards but no more being on the roof!
Today I was hoping to get some of the siding done but took it slow on other things I've been putting off, T bracing on the bottom chord of the side trusses and on the angles in the middle. Also started on the 2x6's between the paired trusses on the bottom chord, and finished putting the 2x8's around the roll up door holes and put in the last spring block. Still a little bit of work left on the man door hole but it's close.
I bought a couple windows on Friday since I didn't think about adding them before I started... I think I'm going to add in another if I can find a pair to one, there's a place by work that has new unused windows for $5 per square foot that were left over from customer projects...
Mostly tinkering stuff at this point but it's getting close! Once I get the siding on I need to figure out where I'm putting things like the bathroom/utility room and office/loft so I can get the electrical in through the concrete. Then I gotta order and spread I think around 24 yards of gravel and the other tinkery stuff I have planned...
Here's this weekends progress.
This metal siding with insulation takes some time especially alone... That wall took some time, only 4 of the sheets of metal didn't need cut of any sort, two were just a simple corner cutout for the trim, 4 pieces needed cut 3" shorter and 6 were major surgery :). That said, the hard wall is done and now I know more... I got one more bay wall covered on the other side since I had some daylight left... Looks like the weather next weekend will be decent too so hopefully I can get the walls done.
   / New shop build, beginning stages with questions #113
I like your color choice. What are you using to cut the metal? For length, I usually use my 7 1/4 inch saw with an old, dull, framing blade in it backwards. For more detail cuts, I use a 4 1/2 inch grinder with a cut off wheel.
   / New shop build, beginning stages with questions #114
I used to cut sheets of steel like you do Eddie. I got tired of the noise and jagged edges. Now I cut with a simple set of non compound regular tin snips. It's a bit of a pain over the ridges but it's quick and quiet.
Combination of brand new Milwaukee tin snips, an electric shear, and an air powered nibbler depending on what I'm cutting :)
   / New shop build, beginning stages with questions #116
Yep, that's me. Circular Saw is way too violent.
yeah, and I read something about it overheating the cut and rusting early... didn't want to deal with that, combination of the manual shears and the nibbler seems to go good across the ribs if you cut the deep one manually it will go over the rest of them. I did buy a metal cutting circular saw blade anticipating its use but I'm more turtle than hare...
The new manual snips are key... I've never used new good snips before, cut like butter and will cut a hair off the edge if you want to! Plus the Milwaukee snips have more of an angle than the normal Wiss so your knuckles are out of the way, and only $34 for the pair of left and right at Home Depot... I think $2 more than the 3 pack of Wiss
Made good progress today, got the gable end wall metal stacked out so it's easier to use and found out I'm short a piece of metal, dangit...
Got the all the sheets up on one end wall, it got dark before I could get done so I had a light out and the wife helping some and while trying to put the third screw into the last piece of metal I fell off the dang ladder... Feet about 5' off the ground, tail bone hit first then back then head... apparently I'm still young enough to bounce back since my tailbone is about all that's sore other than a couple muscles. This happened a few hours ago and I still am not sure how I lost my balance... whatever, the scratch down the side of the metal at least has a story...
Tomorrow I'll finish putting the screws in that last piece of metal and get the top and bottom trim on, and put the bottom trim on the first wall I did last weekend and probably the one corner trim I can do. I haven't been able to get the window trim since the company that does the metal was closed for the smoke...
   / New shop build, beginning stages with questions #119
Sorry to hear about the fall. Hope you don't wake up tomorrow in pain. Maybe take something before going to bed tonight?
I think I'm going to buy some new snips and will look at the Milwaukee ones this week. I'm waiting on my metal order for a porch that I just built for a client, and then I have another porch to build next month. If they cut as nice as you say, that would make life a lot nicer then dealing with the saw blade, or grinder.
Woke up better than when I went to bed! Still can't lift my left leg more than 6", some thigh muscle is mad, not bad, all sorts of bad scenario's ran through my head as I was falling, this isn't bad, task failed successfully! :)
I like the snips enough that I just used them to cut the angle across the whole end wall instead of firing up the compressor to use the nibbler, I think this was faster... and with the extra angle of the blades not one cut knuckle and I wasn't wearing gloves...
2000 Gallon Fuel Tank W/Pump (A50774)
2000 Gallon Fuel...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2016 CATERPILLAR 257D SKID STEER (A51242)
2016 CATERPILLAR...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2013 John Deere 824K (A52128)
2013 John Deere...
