New shop build, beginning stages with questions
   / New shop build, beginning stages with questions #151
I'm not sure I get the sonotube bit, what's that for? I've given up on the gantry idea, if I go with a 2' grid of rebar suspended on the brick things it should be good to go and have the PEX zip tied to that with 12" spacing or more. Looking online a 9000lb lift should be perfectly fine on a 4" slab so flat 6" should be just fine without anything fancy.
As far as spacing for the lift, my longest vehicle is I think 22' long (crew cab long bed '97 F350) so 14' from the door should be fine for the center of the posts.
Rather than having the 4x13 box for the lift, the sonotubes would create two 24" or whatever size you chose circles where there would be no steel or PEX. And if you thought necessary, no gravel in the tube would put your concrete thickness greater.
Again, I suggest you visit a shop using two post lifts and see how far from the door their posts are. I only have a four post lift so can't help you there. I'll text my boys and ask about theirs. They use two post lifts.
Yeah, 14' might work. My Son has a crew long bed SD. I'll get a measurement from his shop for you.
In regards to PEX. Everyone around here staples the PEX to the insulation board. Then suspends the steel above it using chairs. PEX is laid 12" spaced. One foot of PEX for each square foot of floor space. Loops usually 200' long. As equal as you possibly can. The length can be varied to fit the length of your rolls without waste.
In regards to Drilling holes for the lift post fasteners. The "experts" prefer to use the "wedge" type bolts. They also drill their holes clear thru the concrete if possible. Reason being if one fails and won't bind itself to the concrete they can just drive it down thru the concrete into the dirt with a second bolt.
   / New shop build, beginning stages with questions #152
They install those lifts in all sorts of older buildings where no provisions were made for thicker steel. Most lift platforms have large bases to spread out weight. I have powered up lots of them placed in 30 year old garages and shops. Now having pex heating tubes present....that could be an issue. Need to plan around lift. I have seen so many of those tubes ruptured over the years. Also, better plan on investing in a good infrared camera device. There great for finding the tubes as long as unit is running and producing heat.
It's not the weight on the lift pad that's the issue. It's having solid enough concrete to withstand the prying effect.
I've personally never heard of a PEX tube rupture buried in concrete. I think the concrete would have to crack and move apart to do that.
   / New shop build, beginning stages with questions #153
My concrete guy warned me that the plastic chairs would just get pushed into the styrofoam. I made a form to pour concrete and then cut to length. 1 1/2" x 3" across the bottom and tapered 2 1/2" high, with a recess to hold the bar in place. The little chairs I made did a good job of keeping the rebar at the right height. 1250 square feet inside and I made over 400 of them. The concrete crew had never seen anything like it.
I think if the pour crew repeatedly stepped directly on the chairs they might collapse some of them. I don't think they would get pushed into the pink board unless you were using cheap styrofoam that looks like a coffee cup. The advantage of squared rebar is the crew will rarely step on it. They'll purposely try to step in the squares. Can't do that with mesh.
   / New shop build, beginning stages with questions #154
My Son with the Crew Cab Long Bed Super Duty says his lift posts are 17' from his overhead door. He says when lifted his truck rear bumper is 4' from the door.
If you go 14', you'll only have 1' of space between the truck and the door. I don't think you'll like that.
   / New shop build, beginning stages with questions #155
Im not talking about breaking, i mean someone drilling thru them. Last house i wired cabinet maker bolted down island right thru pex tube.
   / New shop build, beginning stages with questions #156
Sorry, I was responding to your comment about large bases to spread out the weight.
Drilling thru the PEX is what I'm avoiding by suggesting sonotubes. It's what the OP is avoiding by leaving his 4x13 ft box empty of PEX.
   / New shop build, beginning stages with questions #157
Nearly all of the units i have hooked up are 4 base units. Personally for myself, i feel safer working under a 4 post unit. Even though i know the 2 post are just as safe. Just look like a humpty dumpty situation to me.
   / New shop build, beginning stages with questions #158
Two post takes up less space. Four post always takes up the same space. I almost always have a Jeep parked on my four post so the space isn't wasted. Newer four post units are mobile with mechanical casters that can be raised/lowered.
I prefer my four post for ease of use. It has two air jacks on it so rotating tires or doing wheel work is easy. Provides great workbench for tools and parts while working.
Two post overall is best for a variety of work.
Best part of a four post is it's use as a Buffet Table for Shop Parties. :)
   / New shop build, beginning stages with questions #159
i built my shop 24 years ago....
And its too short for a lift. If i was to do it all over again i would have it designed for one. I would LOVE to have one. And there not even expensive.
   / New shop build, beginning stages with questions #160
My Sons got together with a couple friends and bought four 2 post lifts at the same time. I believe they were around $1,500 each. Will lift their Diesel pickups, 10K I believe. My four post is 12K and I bought it used from an auto dealership. I gave $400 for it and $400 for a pair of used air jacks.
UNUSED JCT SKID STEER QUICK ATTACH 84" DOZER BLADE (A51244)
UNUSED JCT SKID...
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
AMG M 35 A2 C drop side 2 1/2 ton 6 x 6 truck (A50323)
AMG M 35 A2 C drop...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
Irrigation Pump with John Deere 4045 Engine (A52128)
Irrigation Pump...
2013 Chevrolet Caprice (A50324)
2013 Chevrolet...
