new saw
/ new saw #41
And OILERS are EPA problems. I had to upgrade my oilers on both my 660's to get a decent amount of oil output.
Every Echo that I've seen, they all have adjustable oilers and the 3 I own have no oiling issues whatsoever. Of course I use real bar oil and not used motor oil either.
/ new saw #42
If you were looking at getting a new saw, and have the need for a 24 inch bar with the option of using a 36 when needed to cut off stumps what would you get.
An Echo is a good saw but a Stihl runs faster and therefore has mare chain speed and cuts faster. As for the other comments, I’m not sure I would worry about having a 36” bar for occasional use either.
/ new saw #43
Dyno run of all the saws together. The blue X marks the echo 7310 how it compared to rest of saws in class for HP and TQ.
It was lowest in both.
And yet, it has a 5 year warranty and is plenty capable for my large Burr Oakes. Not the fastest, not the lightest, but a fine saw for me. Expensive I’ll grant you, but I'm happy with it. BTW, the oiler has no issues with a 32” Bar.
/ new saw #44
I have a Stihl 661C with 25" and 36" bar. It ill pull the 36" great in oak. I'm sure others will do similar but I have experience with this one and would recommend 100%.
/ new saw #45
I love Echo saws. I own a few of them and enjoy each one. Some of the models are better than Stihl or Husky and some of them aren't. But one thing is for sure, Echo's warranty flat out sucks. They give you a 5 year warranty but will do absolutely anything to deny a warranty claim, and even if they do approve a claim, you're still out of pocket for their warranty fee. I don't buy any saw based off it's warranty.
/ new saw #46
Interesting that you guys are all Stihl or Echo fans. No one mentioned the Husky saws that would work for the OP- the 572, 592, 395 are a few of the obvious choices that come to mind. Some reason no one here seems to be a Husky guy?
/ new saw #47
Interestingly, you guys are all STIHL or Echo fans. No one mentioned the Husky saws that would work for the OP—the 572, 592, and 395 are a few of the obvious choices that come to mind. For some reason, no one here seems to be a Husky guy.
With the exception of my compact tractor, all my yard equipment is Echo. Other than collectors, I think many will choose their favorite manufacturer if they're happy with their first purchase. I do believe the STIHL owners are the most dedicated.
/ new saw
Personally I am not a Husky fan either.. Even though my 24" bar and chain would fit any of the models you listed, but would have to go with the 3120XP due to my 36" being .404 if I wanted to keep using my current bar and chain.
/ new saw #49
Here’s a 500i running a 36 full comp square ground chain, then a 395 that’s modified setup for running long bar with a 36 semi skip square ground chain both of these saws are in the same stand of timber.
/ new saw #50
I have two Husqvarna pro-level saws and a Jonsered "pro-ish" saw (pro construction, magnesium case, but not billed as a pro saw). I've been very happy with all of them. I'm not particularly brand loyal. Frankly, I just ignore the folks who say things like "brand X, all day" - implying that anything from brand X is better than anything from brand Y or Z for everyone's needs. I'd buy a Stihl saw if I liked one in a size range I was looking for. Husqvarna used to have a several great servicing dealers in my area, but they have retired or passed away over the years. There is still one decent Stihl servicing dealer in the area (a tractor dealership who also takes their Stihl product line seriously). I'd also consider Echo, if only they had a good servicing dealer in my area.
I have zero need for a 36" bar, so don't have personal experience to contribute on that score.
/ new saw #51
Dont get me wrong. I love echo stuff.
Just not that saw in stock form.
You can take the so called 5 year warranty and throw it out the window. What it is really worth.
But hey long as you think it is there is good enough till needed.
/ new saw #52
I'm very much a husky guy and would choose most Huskys over a Stihl any day. All depends on the saw though for me.
/ new saw #53
Older husky here for me.
Not so much into their newer stuff.
OP ask about 661 500i. So rolled with what he ask.
/ new saw #54
That's about what I paid for my 660's and 880, all three slightly used and bought from 2009-?2014?.
Around here, a used 066/660 starts at $600 but there aren't very many of them. At that price, plan on having to do a fair amount of work on the saw before you run it much. At the very least, it would need all new seals and boots. Most of the 90cc saws around here were bought by a farmer or firewood cutter who thought they needed a pretty big saw. There are noticeably more used Stihl and Husquvarna saws in the 70cc class around here, but they bring a noticeably higher price. The logging industry mainly does hardwoods around here, and they seem to favor the lighter 70cc stuff over the heavier 90cc machines.
Truth be told, I actually bought my G660 because in 2021 you couldn't find a 70cc-90cc saw in running condition anywhere. I had dropped an oak in my back yard that measured about 7' across at ground level. I have an 064 that I was using at the time. I wasn't paying enough attention and it started running a little lean on me (may have an air leak), and it smoked the top end. I needed a big saw and I needed it pretty quick. The G660 was at my door in 2 days for about what it would cost if I rebuilt the 064 myself. I still need to rebuild the 064, it's a good saw.
Something worth noting, when you get to a 32" bar (or longer), its worth considering a semi or full skip chain to provide more room for chip clearance.
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
Traxmax 300 Stand-On Tracked Sod Installer (A59228)
Traxmax 300...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
