New RTV-X1100C clunking wheel noises.
   / New RTV-X1100C clunking wheel noises. #131
I found the rear bushings at our local welding shop, i don't have a lathe either i just used a bench grinder and got them close so i could press them in. Then I used a drill bit to make the internal dimension correct.
The front bushings I found at our local surplus center (not sure of their original use) pressed them in and used a drill bit to correct the internal diameter. They work great. I will get back to you on the original dimensions of the bushings and photos.
   / New RTV-X1100C clunking wheel noises. #132
Thanks! I think I will get a couple of the oem plastic bushings and use them to try and size the brass ones! I really appreciate the help
   / New RTV-X1100C clunking wheel noises. #133
This is unfortunate. The last thing I want to do is spend $25k on a machine that requires dealer work to correct factory mistakes.
New/Unused 14ft Bi-Parting Iron Gate (Cow Design) (A57454)
New/Unused 14ft...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
17501-FL (A56857)
17501-FL (A56857)
TUGGER TRAILER (A58214)
TUGGER TRAILER...
2004 Ford F-350 4x4 Flatbed Truck, VIN # 1FDWW37P44EC81012 (A57453)
2004 Ford F-350...
