New RTV-X1100C clunking wheel noises.
   / New RTV-X1100C clunking wheel noises. #131
I found the rear bushings at our local welding shop, i don't have a lathe either i just used a bench grinder and got them close so i could press them in. Then I used a drill bit to make the internal dimension correct.
The front bushings I found at our local surplus center (not sure of their original use) pressed them in and used a drill bit to correct the internal diameter. They work great. I will get back to you on the original dimensions of the bushings and photos.
   / New RTV-X1100C clunking wheel noises. #132
Thanks! I think I will get a couple of the oem plastic bushings and use them to try and size the brass ones! I really appreciate the help
   / New RTV-X1100C clunking wheel noises. #133
This is unfortunate. The last thing I want to do is spend $25k on a machine that requires dealer work to correct factory mistakes.
New/Unused IRMC Massage Chair (A57454)
New/Unused IRMC...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
New/Unused CFG Industrial QK20R Mini Excavator (A57453)
New/Unused CFG...
72" Rock Bucket (A57148)
72" Rock Bucket...
2019 Ford Edge (A55272)
2019 Ford Edge...
JMR 96in Forklift Safety Basket (A56857)
JMR 96in Forklift...
