New PT1430 arrived.
/ New PT1430 arrived. #81
Yes, normally you need to kick the bottom out. You can put the PT plate flat on the ground which is more than many CUTs but not as much past vertical as most CUTs.
Ken
You could get more angle to suit the attachment if your transfer bar had more holes like mine.
My transfer rod IS I in X 2 in, with three 3/4 in holes.
You could make your own with as many holes as you want.
OR add another cyl with variable adjustments.
The picture is a PT-425
/ New PT1430 arrived. #82
I added an adjustable top link but you either can get good back tilt or good front tilt but not both. I have thought about using a hydraulic cylinder with manual shutoff valves to hold it in place when I need my extra circuits for something else. Just seems like the project is not worth the effort when I do not need it but then when I am doing a lot of bucket work, .......
Ken
/ New PT1430 arrived. #85
Thanks for the picture rotation. I use a regular camera; xfer to my Windows computer; rotate in Windows Explorer to save at the correct angle for myself. Then, I upload to forum, but the uploaded file reverts back to the original angle...??!
/ New PT1430 arrived. #87
Now that's one sweet looking tractor .. :thumbsup:
/ New PT1430 arrived. #88
I remember seeing this last year on Brian's gooseneck trailer when he dropped off my PT 425. Wow, that was cold morning! About 0 degrees. I was wondering how well these PT 1430's start in cold weather? That morning Brian told me it would start right up, as where the 425 obviously wouldn't.
/ New PT1430 arrived. #89
Bringing this back to the top...
My old 1430 also has the transfer rod with three holes (one on one end and two on the other), and I will be facing the whole rollover/tilt issue with the newly-ordered EA Wicked Compact 50" Grapple. It appears that the back of that grapple, designed for skid steer QA use is only angled/tilted forward about 10 degrees -- considerably less than the PT's approximate 20 degree angle. Based on some experimentation with my pin-on rock bucket, if I use the shortest hole, I get essentially no dump capability, but the bucket will curl upward too far. At about 2 feet off the ground the back of the bucket is about vertical, with the curl/tilt control in the "far down" position. If I use the "longest" hole, the bucket will dump about like my old 425, and curl up slightly for carrying a load in the bucket. So, that appears to be the general length of choice. Using the "shortest" hole may come in handy for using 3-point implements that have been adapted for use, with a vertical QA plate attached. (I've also ordered an EA 60" Land Shark Land Leveler for grading my gravel driveway, so I will soon get to experiment with that. Land Leveler Land Plane Land Grader Scarifier Shanks for Compact tractors by Land Shark Attachments )
Now onto my real question/issue for discussion. Since I have the lift and tilt rams/cylinders from my old burned 425, I am considering plumbing in one of those to use as my "top link" to make it infinitely adjustable. (At first glance it appears that the lift ram/cylinders would work best due to retracted length being closest to the shortest hole on my existing transfer rod.) I'm thinking of using simple "Tee fittings" so that both the existing and added tilt/curly cylinder would extend and retract simultaneously -- does anyone see any issues with this approach?
My initial concern is getting the added hoses to that second cylinder long enough to handle the full range of motion on the rollover bar's arms, yet keep them as short as possible and protected as well as possible so they do not get "caught/fouled" in the constantly movement of those rollover arms. (My old 1430 has NO hydraulic hoses on the lift arms, and I'm trying to plan out how to route them and protect them as much as possible, welding on tabs/brackets as necessary.)
Thinking this over, I may have to add "stops" on that rollover bar so that I cannot accidentally tilt/curl the attachment up or down too far. I think I may be able to carefully weld on heavy stops on the lift arms and a corresponding tab on the rollover housing -- but I haven't really experimented with that yet... Picture how the stops are welded onto the tractor's male QA plate mechanism to limit how far the individual QA dogs/locks can retract.
Are there other things I should be considering -- or re-thinking? I'm trying to plan all the needed mods to my existing lift arms to convert it to a T-8 QA so I remove the arms and get all the needed welding done at one time. My little 140 amp 110v Hobart can tack on a tab or something, but I can't get sufficient penetration on the 1/2" lift arms to do much there -- only on the crossover "tubes/pipes".
As a couple side notes:
(1) I also considered making a T-8 > skid steer QA adapter like discussed earlier in this thread -- but I decided to forego that approach since it would add 100 lbs or so to the lift arms/QA setup. I'd rather buy an additional QA plate or two, as needed, rather than live with that additional weight. So, I am having EA add the T-8 plate to the new grapple as they build it.
(2) The EA Land Leveler is coming with it's normal Cat 1 3-point. I chose their land plane over buying a King Kutter locally for a bit less money for two primary reasons:
(a) Theirs comes standard with adjustable rippers and provisions for bolting on cutting blades to the back side of the blade mounting bars, and
(b) Just by looking at the pics of it, with its adjustable locations for those cross-bars with the cutting blades, it appears that you could totally unbolt that carriage, and reverse it -- allowing you to set it up to be pushed rather than pulled. (Backing these articulated machines with an attachment on the front in a perfectly straight line is a PITA -- any steering correction swings that implement much more than it effects the steering.) No other land plane that I've seen has that capability. Based on my experience both a box blade and the snow/dirt blade, these PTs as normally configured do not push real well -- they tend to climb up onto the attachment when the going gets tough. But, I think the angle of the QA plate is a factor in this -- because it is tilted forward when the implement is at ground level, forward force tends to push the lift arms UP when pushing hard, preventing you from using float position on the controls. But, if that QA plate was mounted vertical, perpendicular to the ground, this upward force could be reduced somewhat. (Note there is no need to curl a box blade or land plane up and down as much as a bucket.) As a last resort, my oldie 3-pin setup has provisions for a push bar down low, connected just above the front floor of the tub underneath the loader arms. If necessary, I could even adapt or fabricate a similar push bar for the landscape plane. So, I have hopes of being able to push it -- if not successful, I can always pull it.
/ New PT1430 arrived. #90
Have you considered adding an electric selector valve to the dump/curl circuit to operate your adjustable link from the joystick with a button push?
/ New PT1430 arrived. #91
Hmmmm! No, I had thought of dedicating the current manual Aux control valve to the QA setup, and adding solenoid valves to control the Aux functions for the grapple and minihoe (I hate having to reach over with the left hand -- remember I shade-tree engineered moving the control handle to the left side of the steering wheel on my burned 425). I often want to curl the attachment and close the bucket/grapple at the same time -- and that requires two hands...
Maybe two sets of electric valves and 4 buttons on the joystick handle! :laughing:
Great suggestion!
/ New PT1430 arrived. #92
I thought about adding an electric diverter valve to switch the Aux PTO (quick attach handle) and the power angle for my snow plow, so I wouldn't have to reach down for the quick attach handle. But after years of use, I find I just leave it straight most of the time anyway, and only angle it maybe twice the entire time I'm plowing. So I never did it.
/ New PT1430 arrived. #93
Using the minihoe, you are constantly curling and uncurling the dipper bucket. On the grapple, not quite so much -- during transport, all you need to do is occasionally clamp down tighter, but when filling and dumping the grapple you're constantly controlling the clamping...
/ New PT1430 arrived. #95
I certainly appreciate the extra hydraulic circuits I added.
I suspect the land plane would work better with driving in reverse - less strain on the arms etc (tension is usually better than compression).
Ken
/ New PT1430 arrived. #96
Yeah, pushing dirt with an implement on the FEL arms tends to want to make the machine drive up over itself, especially if you try to do it in float.
/ New PT1430 arrived. #97
Yes, to both Ken and Moss's points, but here was my thinking:
1. By mounting the QA plate vertically on the land plane, and using the shortest hole on my toplink, I think the tendency for the tractor to climb up onto the attachment will be much less - how much is yet TBD. IMO, the normally angled QA plate forces the lift arms up when pushing hard. To use a landplane or box blade effectively they must be able to float.
2. My limited experience with this old 3-pin setup and it's push bar so far shows that the push bar makes a big difference. I can push my finish mower or rough-cut uphill or into areas, using float, where I would've had to lift my QA attachments slightly to continue. Having the ability to transmit force down low, parallel to the ground makes a significant difference. This 3rd point is down below the center of the wheels, similar to the fixed drawbar on a 3pt tractor in comparison to the drawbar on the 3pt lift arms. The force when pushing tends to push the tractor down slightly rather than lifting it, though most is transmitted parallel to the ground. Both my 3-pin mowers simply hang underneath the lift arms, with no toplink used, and all pushing is done with that push bar...
Whether or not I can effectively push the 500 lb land plane (485 + the QA plate), especially in float, is yet to be seen. But this EA one at least should let me experiment to see. Meanwhile, I can pull it, as intended...
Also, this discussion has been quite valuable - for example I've now concluded that for a hydraulic, adjustable toplink to work effectively, I can't simply "tee into" the existing curl circuit and let both cylinders move at the same time. That second cylinder would need to be independently controlled by a valve (whether mechanical or electric solenoid) -- otherwise you could end up with undesirable placements - such as the toplink fully extended and the lift/curl cylinder retracted.
This brain-storming is invaluable!
/ New PT1430 arrived. #98
The forces will always be better pulling than pushing. Extra load in pull adds down force to the drive wheels, while extra load during pushing adds load to the implement, reducing the traction at the drive wheels. Whether there is enough left for what you want to do...only you can tell.
All the best,
Peter
/ New PT1430 arrived. #99
Yep. If you Tee them together, the one with the least resistance would operate first. Which one? Who knows. :confused3:
Coats 1550 3D Wheel Balancer Machine (A61573)
Coats 1550 3D...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
203201 (A60429)
203201 (A60429)
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
