marrt
Platinum Member
Since I’ve had my PT425 about a week now, I thought I would post some observations.
Background
I have about 3.2 acres of lawn and pasture. There are some small hills and a few rough areas. The lot has no trees and my primary tractor activity will be mowing. I looked at both the PT and BX2000 and eventually decided on the PT for the following reasons/benefits: ability to have front mounted attachments, heavy duty construction, maneuverability of the articulated design, full time four wheel drive, larger operator’s station, and the quick attach system. Unfortunately, I gave up the legendary Kubota diesel engine and availability of a strong dealer network and ready resale market.
The Tractor
I purchased the PT425 with the large bucket, the small bucket with teeth, the post hole digger with 18” auger, the fork lift attachment, the small steel trailer, the potato plow, the 60” mower, and the tiller.
Positives
Many of the concerns that I struggled with initially turned out to be non-issues. For example, I was originally worried about using the mower over rough terrain and the quality of cut, since this is my primary usage requirement. I find that the mower is very comfortable on rough terrain and the cut quality far exceeded my expectations. Having the mower in front of the operator is absolutely outstanding and the rear discharge means no ugly windrows. Also, I am impressed with the overall traction and the digging ability of both the large and small buckets. I can easily get a full scoop of dirt in either bucket, even though I had no previous FEL experience. I got the bar tires and I’m glad I did. They have incredible traction (I can even stall the tractor before they spin in some circumstances) and do not damage the lawn at any speed. Also, I’m glad I choose the 425 over the 422. I find that with the 60” mower, there’s certainly not a lot of reserve power on hills. Also, the ROPS provides a great “hand hold” over rough terrain. Overall, I would also say that the ride is better than I expected as well.
The Bad
I won’t dwell on the negatives hear, since I have another thread open on this subject, except to say that I have had a number of small problems. The hour meter did not work, the drive peddle had a bolt come completely off, the pin-in-slot brake was not adjusted properly and was trying to engage even in the off position, I blew a fuse to the fan for some, as yet, unknown reason, and my battery leaked for some reason and took off quite a bit of paint. Even though I have only 3 hours on the tractor, I’ve already spent more than 5 hours working on it and, at the moment, it is unusable due to the battery leak problem. One thing's for sure: I need to Chalkleyize this machine as soon as possible. Hydraulic and Engine Oil Temp Gauges as a minimum (Mark, what else?).
The Jury is Still Out
I’m not that concerned about the small quality control problems I’ve had to date (hey, even the bota’s have had a few problems) but I am concerned about the overheating problem, which I believe precipitated the battery leak. I don’t know what caused it, I don’t know how to fix it, and I don’t have the time to trouble shoot a new tractor. This is the one big drawback to purchasing a PT. If you do have a problem, there no calling the dealer to come get it and fix it. Sure, you can get phone support from PT, but it’s your time and effort, in the end, that will fix the tractor. I’ll keep you updated.
Background
The Tractor
Positives
The Bad
