New PT-180 owner
   / New PT-180 owner #111
I have only done it with pry bars, and not for a long time. And no, I don稚 miss it. It was a bad combination of bad roads, bad Firestone tires that at one point gave us seventeen flats in six weeks. We got really good at tire changes and repair. Practice makes perfect and all that. We went to Michelin tubeless and had one flat in eighteen months on the same roads. Ask me which brand I have bought for the rest of my life...
That tire replacement stand takes a lot of stress. So, you would probably need to bolt it down, which means having a permanent spot for it. That alone would keep me from doing it. You may have more room in your shop than I do.
As always, YMMV...
All the best,
Peter
I have room. Will have more by fall, hopefully.
   / New PT-180 owner #112
On that subject, how many of you to your own tire removal? I found out a trick that works really well to get the tire off the rim....
take it to a tire shop. :D
My brother who lives next door has a commercial tire changer, but I have so much trouble getting these tires to take air and set the bead that I still take it to a tire shop. Anybody got any good tricks for that?
   / New PT-180 owner #113
Personally, I found that a little bit of bead sealant/lubricant makes a huge difference. I used to use Murphys oil soap. After that, it is figuring out how to jiggle the sidewall to get the bead to catch on the rim. I know pros who use a cheetah but it is pricey...
But I prefer your solution. :)
All the best, Peter
   / New PT-180 owner
I have used a cheetah before. I worked at a rent to own company that did wheels and tires and we used the cheetah to launch lug nuts through the bathroom door when a guy was in there. Typically if I needed to seat a bead I would stand the wheel up with the unseated portion facing up and lower the fingerlift (with vehicle on it) down to squeeze the tire and push the sidewalls out. Then with the pressure on the wheel you add air and the bead would usually seat. It was faster than the cheetah. However, any type of lube will work to help the bead seat. We only worked with low pro tires so sometimes the lube wasn't enough. (Think 24"+ wheel with a 20 sidewall)
   / New PT-180 owner #117
I found it harder to do the small tires/wheels then car size and up. At a tractor engine show I bough a antique machine like the one Moss shown and it works great. To save space I bolted to a slab of concrete and use the forklift attachment to bring it inside when I need it.
   / New PT-180 owner #118
:thumbsup::thumbsup::applause:
   / New PT-180 owner #119
Dang, I'd never even heard of a cheetah before. Looked at it online. I see a real Cheetah costs $400, but I see knock-offs on EBay for mid 50's. Are they any good or an accident waiting to happen. Like M5040 says, I never have trouble with car or truck tires that a ratchet strap won't fix, but these little tractor tires give me fits. My buddies growing up used to have an inflatable tube that would fit around the tire to compress the bead and that always worked pretty well, but I haven't seen one of those in years.
   / New PT-180 owner #120
I would go for whatever works for you. Ratchet strap, jiggling, cheetah, rubber bead seaters, pneumatic bead seaters, they all kinda work. Anytime that I see a dozen solutions for a problem, I think that all of the solutions are about as effective. The only one that I wouldn’t recommend is butane/propane. (YouTube it. Definite Darwin Award material in my opinion, but YMMV...)
All the best,
Peter
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
2008 Sterling Bullet Utility Truck, VIN # 3F6WK76A88G352277 (A54865)
2008 Sterling...
Black Metal Rail Panel (A55758)
Black Metal Rail...
2010 INTERNATIONAL DURASTAR 4300 CHEMICAL TRUCK (A55745)
2010 INTERNATIONAL...
