New project: Front Snow Plow
   / New project: Front Snow Plow
Added a home made 1/4" thick x 3" Carbon Steel cutting edge to the plow.
Drilled it dead center, so it is reversible.
Mild steel would have probably been fine, but, this was available and not much more $$$
Carbon Steel Cutting Edge
To finish up this thread and project, here is the final-final picture, in action.
More info can also be found in the thread about the rubber snowplow edge.
Snow Plow Test
This reply is to simply tie this thread to the other thread.
LBrown59 said:
How do you like your tiller?
I have a 48'' KK tiller and can use it on my BX23 or either of my BX1500S.
The 48" KKII (TG) gear drive tiller is great. I've done quite a bit of landscaping with it recently, it runs fine.
The rating systems used by implement manufacturers is sometimes skewed. In this case they tell you minimum of 20 HP PTO for the 48" KKII. I am having no problems with power, I have power to spare.
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A57024)
2023 Unverferth...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
