New problem with our HST
/ New problem with our HST #1
Qapla
Gator Country
New Holland TC40D HST 4WD FEL/BH
We have a NH TC40D with a FEL and BH.
Using it today I found a new problem ... I was trying to dig out a stump and when I positioned the tractor I discovered that the FEL will no longer lift the front off the ground. Even using the "tilt", it would not lift the front off the ground - it used to.
Also, when I had to drive out into the field quite a distance, I used Range II like I usually do. When I started, I was in "turtle", then I hit the button for "rabbit" and the machine bogged and almost died.
Later, we had a hose break and, when we brought the tractor over to take the hose off, we checked the hydro fluid dipstick. It did not show - the tractor was running.
Should we check the fluid with the tractor running or off? Also, would low fluid cause these other problems?
LEEBOY SUPER 400 DOUBLE DRUM ROLLER (A65053)
LEEBOY SUPER 400...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2yd. Skid Steer Trash Hopper (A65640)
2yd. Skid Steer...
