New Plow
/ New Plow #11
My pivot pins were pretty much rusted solid. Plow wouldn't move so I put some heat to it then penetrating oil thenpushed/pulled it against a tree and finally broke it loose. I plan on replacing them at the end of the season if I can get them out.
Jeff
/ New Plow #12
Replace them now, before it gets expensive.
When I broke mine, I tried a propane torch. NO way that was going to work.
I took the plow to a welder and they used am Oxy/Propane torch to cut everything out. Lots and lots of heat and a BFH finally got everything removed. Both pins were almost welded in because of the rust.
After welding replacement tubes on both the plow and frame, put the new pins (w/grease fittings) in. Pumped lots of grease into the new pins to hopefully prevent rust.
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
Pittsburgh Heavy Duty Solid Steel Auto Ramps (A59230)
Pittsburgh Heavy...
