New owner questions
/ New owner questions #61
The only drawback with reversing the pins if you have outside chains is every time you switch implements, you have to loosen the chains.
Eugene
/ New owner questions #62
Eugene
/ New owner questions #63
That is true and I do. It only take a few seconds extra though.
/ New owner questions #64
/ New owner questions #65
Loot at the where made sticker on the 4110. Acording to tractordata.com it was made in japan which means it is a Yanmar.
/ New owner questions #66
/ New owner questions #67
I already knew it was a Yanmar, or I probably wouldn't have bought it. It says Yanmar right on the motor. That is what I was saying, the Yanmar I had was from around 1977, and they are still building them the same way, so if its not working for you, then that means you must be doing something wrong.
/ New owner questions #68
/ New owner questions #69
I use crossed chains with no problems on my 1602D, and yes those rear tires are narrow. The pins on my implements are on the inside, with my crossed chains it works easily for mount/dismount..............
For pins pointing out, the outside chains would work better........
/ New owner questions #70
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
