New Owner - Electrical question
/ New Owner - Electrical question #1
tbohn
I have just acquired a F20D with a FEL and box blade. It's in pretty good shape, but needs work on one of the electrical circuits. It has a joystick and two knobs on the right fender. The stick controls tilt for a blade on the 3pt hitch. Is anyone familiar with this option? Also does anyone know of electrical diagrams for this machine?
Thanks, This forum was a good source of info during my purchase decision.
T-Bohn
/ New Owner - Electrical question #2
The joystick was designed specifically to control the tiller that came as original equipment with the tractor. I'm not sure how it is supposed to work, but I think it was supposed to be self leveling. One of the knobs should override the auto-leveling and allow you to adjust the tilt to wherever you want it.
The parts manual may contain a wiring diagram. Ask the dealer where you bought the tractor.
/ New Owner - Electrical question #3
We are very familiar with the electric solenoid 3tp hydraulics. Give me a call I have the info you need. 509-374-3398 or 509-521-1507
Buck,
Thanks for the info we just discussed and for your offer to send the diagram. I'll give you a call if I run into trouble.
T-Bohn
/ New Owner - Electrical question #5
I have an FX24D with the tilt control (Joystick & 2 swithches) & it has just broken. The joystick retainer ring wore out & the tilt stopped working. I loved the tilt capability. It is great for grading and plowing snow. Don't know why more tractors haven't put a hydraulic cylinder where most have the manual adjust. It's so much easier to hook up implements.
I am in the process of building a FEL (CADPlans 1007) & since I am messing with the hydraulics, decided to just replace the electrical system with straight hydraulic. Needed a double acting cylinder and some new lines. I teed into the input side of the solenoid hydraulics for the FEL feed.
I'll let you know how it works out.
/ New Owner - Electrical question #6
Sorry, replace-"needed double acting cylinder" with "needed a control valve for a double acting cylinder"
/ New Owner - Electrical question #7
I had a Hinomoto with the same type control. When it gave trouble I replaced the fancy stuff with a dual pole dual throw switch. It wasn't as smooth as the joy stick but it worked.
/ New Owner - Electrical question #8
I am up at the lake cabin sun-mon and my diagram is at the office I will send it Tues.
/ New Owner - Electrical question #9
I need your email address to send you the schematic. I should have asked you for it when I talked to you, sorry about that. /w3tcompact/icons/grin.gif
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2001 Ford F-150 Crew Cab Pickup Truck (A61573)
2001 Ford F-150...
2018 Lincoln MKT Town Car AWD SUV (A61574)
2018 Lincoln MKT...
2018 VOLVO VNL780 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2018 VOLVO VNL780...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2018 FREIGHTLINER...
