Buying Advice new or used sub compact
/ new or used sub compact #1
gravelman
Platinum Member
NH
Kubota 2650
gravelman here...looking for a subcompact.. 18 -25 hp.. bucket with quick attach if available on small machine. no cab turf tires.. i had a Mahindra max but sold it...should have kept it. Kubota dealer close by.....any advice?? general work around a 5 acres lot... rototilling..mowing... a general wheelbarrow.
/ new or used sub compact #2
Kubota's sub-compact tractors are the BX series with 18-23-25.5 horsepower. All have 9" of ground clearance.
SSQA, which Kubota calls two-lever coupler, is available on all new BX tractors with FELs. However, this industry standard fixture is heavy, reducing FEL payload capacity 15%, from 820 pounds to 699 pounds.
Kubota B2650 is a well equipped compact tractor, 26-horsepower, with 14.6" of ground clearance.
All good for rototilling..mowing... a general wheelbarrow.
B2650 more versatile than smaller BX tractors. B2650 FEL lift capacity 1,407 pounds.
If you have woods, favor the B2650 for ground clearance.
thank you very much
/ new or used sub compact #4
Ive been looking lately and TBH I would probably go for something in the 24-26hp range its not much more than than like the 18hp versions etc. the 18hp tractors really are just lawn tractors the bigger ones at least let you grow into something if you needed.
As for used and brand new, think it depends on how used you want and what brands, ive looked and really with tractors going used and making it worthwhile in the cost department means getting something a little older. Something new used from what I have seen cost just as much as new. Have actually seen people selling used tractors for more than I can buy them new.
/ new or used sub compact #5
Ive been looking lately and TBH I would probably go for something in the 24-26hp range its not much more than like the 18hp versions etc. the 18hp tractors really are just lawn tractors the bigger ones at least let you grow into something if needed.
ok this is all very helpful....thanks very much
/ new or used sub compact #7
A lot depends on finances. If you want to tie up cash you might want to look at used. Most SCUTS do not get many hours put on them (50 HRs/yr average). Stay away from high hour units like my 1500 Hr one as risk of expensive repairs goes up. You won't save much money though, maybe $2K.
With all the manufacturers offering 0 down/0 interest/60 months why tie up your cash.
Ron
/ new or used sub compact #8
If you go with a used or new BX, I can highly recommend Jery's Tach n Go. I bought the QA and also the adjustable forks. Researched a fair amount and was impressed with the light weight design that did not significantly reduce the lift capability. Two simple levers and quick release pins. I routinely swap out my bucket and forks without hesitation.
/ new or used sub compact #9
Buy a new KUBOTA with zero percent financing for 72 months. Last tractor you will buy. Comes with warranty too! No headaches of finding a hopefully less abused used machine.
ok everyone...thanks alot for all of this... i have a Kubota dealer closeby... always like John Deere but they priced themselves out of MY market...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 FREIGHTLINER T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
Hydraulic rail grinder (A61307)
Hydraulic rail...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
2004 INTERNATIONAL 7400 20FT T/A FLAT BED (A59910)
2004 INTERNATIONAL...
