New Mower.
/ New Mower. #1
Rio_Grande
Platinum Member
Well new mower, Hope I dint just throw 3800 out the window! Now to find a wrecking door.
/ New Mower. #2
It will pay for itself quick, defently be looking for a forestry door.
/ New Mower.
Wow bit of a learning curve but this thing cuts some brush. Haven't cut anything big yet but it goes right through the multi floral roses and rougher stuff I don't like driving the tractor over.
/ New Mower. #4
That's a heck f a mower! Looks like it should get some serious work dne in a hurry!
What's the make and model of the mower? How much flow and pressure does your machine have? What is the average size max diameter that you can efficiently tale down? (I realize you just got it and may not have enough seat time yet to answer the last question :) )
Congrats! Looks like a cool toy.
/ New Mower.
Cant answer the last one yet but in 1-2 inch brush it cuts very effenciently. That is as big as I have done so far. My machine is rated at 19.6 gpm and the machine is rated to 20 gpm. It is a Prowler badged CID brand mower. I will have to find the model but it is 72 in.
It will see some heavier stuff this weekend when I take it to my property.
We have jobs linded up for it on saturday and sunday.
/ New Mower. #6
Thanks for the reply, I'm looking forward to hearing some more about how you like it after getting a little more time in the saddle :D
/ New Mower.
I can say it dosent really compare to a forestry head but it cost 30+k less too. I ran an ASV forestry package a few years ago and it did a much better job of eating everything to the ground. For what this thing is though it rocks in what I have put it in so far.
/ New Mower.
Had it out and did a steep job into a pond, took down a few trees and Grubbed a bit. It cut everything I put too it including an 8is inch ceadar. It was not designed to cut that ceadar and it was aparent but it did it. even chopped it up. But again it was aparent it was not designed to .
The good about it is when cutting grass and trees to 3 inches you just mow and chop. No need to stop or slow down. some of the 4-6 inchers were tough and diddnt just lop off and suck in.
Now to blow this out of the watter. I hit some 8inchish fresh cut limbs that I diddnt see on the ground and it ate them up. but I got off of them caus it scared the crap out of me!!
All in all I still dont compleetly know its limitations because I havent used it enough. When it flings stuff it really throws them.
/ New Mower. #10
That's incredible that it can take down small trees that big :thumbsup:
Seems like a good value for the price you paid vs what it can get done.
/ New Mower.
As long as we can keep business coming in I will love it!
/ New Mower. #12
I ran a Kershaw built rotary that had twin spindles and the swinging blades that were one inch thick. It would easily take down an 8" tree with a lot of noise and some vibration. You could change the direction the spindles rotated, so it was nice that you could have some control of the direction of the projectiles. That thing was scarey. The problem was, that after a while all the steel and welds start to crack from the impact. I would stay away from the big stuff, it will cost you sooner or later.
/ New Mower.
I agree while I know this thing will do the 8" we won't be doing it regularly at least not on purpose. I can reverse mine too, never thought of it throwing it a different way.
/ New Mower. #14
Yep that's the same mower as CID attachments and rootgraple.com.
/ New Mower. #15
My man,
You are absolutely insane to run that without any protection.... Atlleast buy a cup, knee pads elbow pads, shoulder pads helmet and a mouth piece.... Lol. Ohh and don't forget goggles.....you must charge triple so ppl can just watch u run that thing
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
Four (4) Firestone Combine 520/85R42 Tires (A63116)
Four (4) Firestone...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
Bad Boy Z-Turn Lawn Mower (A64047)
Bad Boy Z-Turn...
