New Member
/ New Member #1
woodchuckinthecity
Plano, IL
John Deere 650
We have a couple small tractors, a Ford 600 and a John Deere 650. I'm currently having starter problems with the Deere and I'm hoping to get some help from this forum. I've already seen quite a bit of useful information.
The tractor will not turn over with a good battery and new starter. I'm in the process of troubleshooting the start circuit and safety switches.
/ New Member #2
:welcome: to TBN...enjoy.
/ New Member #3
:welcome: Welcome to the forum!
I'm going to move your thread over to our John Deere section :)
/ New Member #4
woodchuck
:welcome: to TBN
A good place to start is to get a copy of the service tech manual, which will have schematics and the entire contents for working on your 650. Go online, or to your Deere dealer to get a copy. Worth it..
/ New Member #6
Welcome to TBN
Clean & tighten all 4 battery cable connections. Battery cable can appear good but be corroded inside of insulation.
/ New Member #7
Bench test the starter. I've gotten a bad one, new in the box (for a truck, not a tractor) Oh, WELCOME from SW MI. :welcome:
/ New Member #8
Wouldn't turn over before the new Starter either?
What test did you perform to diagnose that you needed to replace the starter??
Do you have battery voltage at the key switch? (In and Out)
What interlock switches have you tested/verified?
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
UNUSED WOLVERINE HYD SNOW PUSHER (A64281)
UNUSED WOLVERINE...
2025 Hydraulic Plate Grapple Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2001 FORD SUPER DUTY F350 4x4 UTILITY TRUCK (A59912)
2001 FORD SUPER...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
