New member from Eastern Washington
/ New member from Eastern Washington #1
shawn sutton
Selah WA. & Helena Mont.
Mitsubishi
Good day all.Been watching this forum for a while now saving up to buy a tractor.Well i got it yesterday and decided to join today.i want to completely restore this tractor.I am a disabled vet and need a hobby to do with my sons.(they are strong and i am inclined.Glad to meet you all.
It is a mitsubishi im not sure yet on model,it has been painted in spots where model would be.it is a 2 cylinder,the wheel base center to center is around 65.i posted pics in the Mitsubishi forum.
/ New member from Eastern Washington #4
and enjoy the forum!
/ New member from Eastern Washington #5
Welcome to TBN and the forum Shawn. Always glad to have more "dry siders" here. You should update your profile and indicate where you are at.
/ New member from Eastern Washington #7
WELCOME.
Seattle person here. Moved to Florida for warmer winters and cooler summers.
/ New member from Eastern Washington #8
Welcome to TBN!
/ New member from Eastern Washington #9
Welcome to the forum!
You'll have to share how your new project is going :)
Well i got it Sunday evening,Put a battery in it to see where i was at with the starter and it clicked turned real slow click click click.I went to undo battery and burned my hand pretty good,Bad short when ignition was on so Monday i chased everything out rewired a bunch of stuff that was hooked up wrong put fuel in and started it up drove into the garage.Started checking all bolts,fluid levels and so on.now when manuals come in i will go through everything and start ordering things i need as i go.
/ New member from Eastern Washington #11
Welcome to TBN...enjoy.
/ New member from Eastern Washington #13
Welcome from VA.
/ New member from Eastern Washington #14
So glad to have you Shawn and thank you Sir for your Service to our Country.
Just got back home,I found a 3 point with rear blade $150. blade new 3 point very good shape except blade mounting plate not very good.I will rebuild the plate
I pulled the cap off the 3 point hydraulic line it was plugged,Oil was milky so i pulled all hoses off(a couple need replaced) and drained all the fluid.
New filter came last night and a roll of hydraulic line and ends.Made new hoses and installed them today.Put new filter in and topped off with fluid changed the oil and fuel filter.Fired it up with no leaks and everything works great.Now it's time to start primer and paint.
2015 John Deere CX15 (A64126)
2015 John Deere...
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
Caterpillar 572E Tracked Pipe Layer (A64553)
Caterpillar 572E...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
Bucket (A64194)
Bucket (A64194)
