New land... need a tractor!!
   / New land... need a tractor!! #131
Wouldn't the difference between a cut and utility be cat 1 and cat 2?
I'm sure that is at least partially correct but there are some CUTs that can use Cat 2 implements. The Kioti NX6010 is almost identical to the NX4510 but the 6010 can be configured for Cat2.
   / New land... need a tractor!! #132
As an extreme example, how many more plow bottoms will a 200hp Ford 8N V8 conversion pull? :)
Bruce
Good one!!!!
   / New land... need a tractor!! #133
Could you guys just get a room or your own thread? I think we scared docsfarm off.
We are probably the only reason this thread is still alive. If that upsets you, then maybe you should unsubscribe?? :)
   / New land... need a tractor!! #134
In my eyes it's a serious consideration. But then that line even gets blurred. My 1984 Ford 3910 is CAT I/II. Interchangeable balls in the lower 3pt arms. :)
   / New land... need a tractor!! #135
My MX 4700 is listed as having a category I/II hitch also. Kubota calls it a utility tractor, but it competes against models known as CUTs by other manufacturers.
   / New land... need a tractor!! #136
Does it have CAT I balls in the lower arms?? If so, are they interchangeable??
   / New land... need a tractor!! #137
I guess having at cat 1,2 mix would be treated as a freak machine.;)
   / New land... need a tractor!! #138
Bihitchual
Bruce
   / New land... need a tractor!! #139
   / New land... need a tractor!! #140
I like this discussion! I've always wondered where the line between CUT and UT was. I think I'll start a thread on that :D
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2002 International 9200i Truck (A52128)
2002 International...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2020 FREIGHTLINER...
Best 30' Grain Drill (A50514)
Best 30' Grain...
CRESCENT  MANIFOLD TRAILER (A50854)
CRESCENT MANIFOLD...
2014 GMC Sierra Crew Cab Pickup Truck (A50323)
2014 GMC Sierra...
