New land... need a tractor!!
   / New land... need a tractor!! #142
You gonna cover the room and damage deposit?:D
Really the OP never participated in this thread very much. Hard to help the OP when he doesn't answer questions and doesn't pose any.
You a moderator now or just being bossy?
That's funny!
   / New land... need a tractor!! #143
Wouldn't the difference between a cut and utility be cat 1 and cat 2?
My MX4800 came cat2 but I don't think it's a utility tractor.
   / New land... need a tractor!! #144
My MX5200 has CAT2. Kubota list it as a CAT I/II. I think they are a CAT 2 ball with a CAT 1 width. Kubota also calls it a Special Utility Tractor. It's framed and sized as a large CUT but has they HP of a small utility. Kind of a hybrid. And the main reason I recommended something similar for the OP. It's small enough to move in the woods and mow but large enough to cover ground when in an open field.
   / New land... need a tractor!! #145
Does it have CAT I balls in the lower arms?? If so, are they interchangeable??
It's got cat 2 balls on all three ends. It came with a pack of bushings to make it fit cat 1 implements. The actual measurements, I'm not sure of, but it's definitely bigger than my 8ns and TC 29.
   / New land... need a tractor!! #146
That's very similar to my old Ford. When hitched to a CAT II implement the arms are almost at their widest position. When hitched to CAT I they are almost at their narrowest position.
The interchangeable balls are held in place by a simple spring clip assembly. I leave the CAT II balls in place all the time and just use bushings to hitch to a CAT I implement.
I really like the setup and don't understand why it's not still offered.
   / New land... need a tractor!! #147
The ball on the implement side of my hydraulic toplink has cat 1 and cat 2 holes.
   / New land... need a tractor!! #148
   / New land... need a tractor!! #150
Here is the pic of the toplink.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51242)
KNOW BEFORE YOU...
2019 Nissan Sentra (A50324)
2019 Nissan Sentra...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 78"...
Westfield MK130-91 Swing Away Auger (A50514)
Westfield MK130-91...
