New land... need a tractor!!
   / New land... need a tractor!! #142
You gonna cover the room and damage deposit?:D
Really the OP never participated in this thread very much. Hard to help the OP when he doesn't answer questions and doesn't pose any.
You a moderator now or just being bossy?
That's funny!
   / New land... need a tractor!! #143
Wouldn't the difference between a cut and utility be cat 1 and cat 2?
My MX4800 came cat2 but I don't think it's a utility tractor.
   / New land... need a tractor!! #144
My MX5200 has CAT2. Kubota list it as a CAT I/II. I think they are a CAT 2 ball with a CAT 1 width. Kubota also calls it a Special Utility Tractor. It's framed and sized as a large CUT but has they HP of a small utility. Kind of a hybrid. And the main reason I recommended something similar for the OP. It's small enough to move in the woods and mow but large enough to cover ground when in an open field.
   / New land... need a tractor!! #145
Does it have CAT I balls in the lower arms?? If so, are they interchangeable??
It's got cat 2 balls on all three ends. It came with a pack of bushings to make it fit cat 1 implements. The actual measurements, I'm not sure of, but it's definitely bigger than my 8ns and TC 29.
   / New land... need a tractor!! #146
That's very similar to my old Ford. When hitched to a CAT II implement the arms are almost at their widest position. When hitched to CAT I they are almost at their narrowest position.
The interchangeable balls are held in place by a simple spring clip assembly. I leave the CAT II balls in place all the time and just use bushings to hitch to a CAT I implement.
I really like the setup and don't understand why it's not still offered.
   / New land... need a tractor!! #147
The ball on the implement side of my hydraulic toplink has cat 1 and cat 2 holes.
   / New land... need a tractor!! #148
   / New land... need a tractor!! #150
Here is the pic of the toplink.
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
John Deere 7000 12 R 30 Planter (A50514)
John Deere 7000 12...
UNUSED AGT YSRT14 STAND ON SKID STEER (A51243)
UNUSED AGT YSRT14...
Irrigation Pump with John Deere 4045 Engine (A52128)
Irrigation Pump...
1991 Great Dane 48' Reefer Trailer (TITLE) (A50774)
1991 Great Dane...
ALL AMERICAN BIG J SERIES (A51243)
ALL AMERICAN BIG J...
