New land... need a tractor!!
   / New land... need a tractor!! #131
Wouldn't the difference between a cut and utility be cat 1 and cat 2?
I'm sure that is at least partially correct but there are some CUTs that can use Cat 2 implements. The Kioti NX6010 is almost identical to the NX4510 but the 6010 can be configured for Cat2.
   / New land... need a tractor!! #132
As an extreme example, how many more plow bottoms will a 200hp Ford 8N V8 conversion pull? :)
Bruce
Good one!!!!
   / New land... need a tractor!! #133
Could you guys just get a room or your own thread? I think we scared docsfarm off.
We are probably the only reason this thread is still alive. If that upsets you, then maybe you should unsubscribe?? :)
   / New land... need a tractor!! #134
In my eyes it's a serious consideration. But then that line even gets blurred. My 1984 Ford 3910 is CAT I/II. Interchangeable balls in the lower 3pt arms. :)
   / New land... need a tractor!! #135
My MX 4700 is listed as having a category I/II hitch also. Kubota calls it a utility tractor, but it competes against models known as CUTs by other manufacturers.
   / New land... need a tractor!! #136
Does it have CAT I balls in the lower arms?? If so, are they interchangeable??
   / New land... need a tractor!! #137
I guess having at cat 1,2 mix would be treated as a freak machine.;)
   / New land... need a tractor!! #138
Bihitchual
Bruce
   / New land... need a tractor!! #139
   / New land... need a tractor!! #140
I like this discussion! I've always wondered where the line between CUT and UT was. I think I'll start a thread on that :D
DMI 3200 Side Dress Bar (A50514)
DMI 3200 Side...
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52128)
Mitsubishi FG35...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
2012 CATERPILLAR 308E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
