New land... need a tractor!!
   / New land... need a tractor!! #41
Go get in a shuttle shift/power reverser and drive it arround a full dealer lot. Then get on an HST. See which you feel more in control with.
Then imagine trees, your house, or a drop off where rollover is a real possibility.
I am much safer on my Hydraulic Shuttle tractor than I was on an HST. Too much uncertainty with HST when on the edge of that drop off.
   / New land... need a tractor!! #42
Me neither. But we are further down this tractor path than the OP. :)
I agree that if he is doing real work that he will need more tractor(s). That is why I suggested early on to get a small used woods tractor and buy a larger cab tractor for the field work. I would expect a much larger long term expenditure closer to $100k than $20k if the OP gets invlolved in working the entire place.
   / New land... need a tractor!! #43
Yeah, I'm at $54K with no cabs.
   / New land... need a tractor!! #44
Just can not imagine tending to 200 acres with what $20k will buy "slightly used".
This is a little more than 20K but not much. While it may not be some peoples first choice, I can certainly imagine using it to tend 200 acres.
2014 Kioti RX7320 with FEL in NY for $24.9k listed on tractorhouse.com
   / New land... need a tractor!! #45
ovrszd is profound. You start where you start. This is Doc's "first" tractor. There are really only 25 acres to tend to. A 40hp to 55hp will do just fine. After he gets the bug, he will buy something bigger and something smaller. In the meantime, I wouldn't mind doing everything he wants top do with my 40hp New Holland.
   / New land... need a tractor!! #46
This is a little more than 20K but not much. While it may not be some peoples first choice, I can certainly imagine using it to tend 200 acres. 2014 Kioti RX7320 with FEL in NY for $24.9k listed on tractorhouse.com
That does seem like a pretty good deal actually. It's definitely the size I'd want for the acreage involved.
   / New land... need a tractor!! #47
gladehound is profound. I would buy that!
Wow. That Kioti you guys mentioned looks like a nice tractor. Bigger than I envisioned for what I was though. But the price and capability is tempting. You all are evil!!! ;) lol!!!
   / New land... need a tractor!! #49
Just go and sit on that Kioti, and drive it around a little. I'm sure you can resist the temptation. Those of us with 2 and 3 tractors have been able to resist temptation, or we would have 5 or 6 tractors by now - Right ???
   / New land... need a tractor!! #50
As you are looking at tractors like the Kioti, consider also Mahindra. Both are big beefy machines and good value for the money. Both very reliable. I bought my Kioti from Rick Wallace in Lake Ariel, PA just east of Scranton. I know it is a couple hours from your property but I cannot say enough about Rick as a dealer. He sadly no longer carries the Kioti line but he does carry Mahindra. Well worth a visit if you get up that way. Wallace Tractor and Equipment NEPA Compact Tractors Lake Ariel Poconos Honesdale PA
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
2017 Freightliner M2 106 24FT Box Truck (A50323)
2017 Freightliner...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
