New land... need a tractor!!
   / New land... need a tractor!! #41
Go get in a shuttle shift/power reverser and drive it arround a full dealer lot. Then get on an HST. See which you feel more in control with.
Then imagine trees, your house, or a drop off where rollover is a real possibility.
I am much safer on my Hydraulic Shuttle tractor than I was on an HST. Too much uncertainty with HST when on the edge of that drop off.
   / New land... need a tractor!! #42
Me neither. But we are further down this tractor path than the OP. :)
I agree that if he is doing real work that he will need more tractor(s). That is why I suggested early on to get a small used woods tractor and buy a larger cab tractor for the field work. I would expect a much larger long term expenditure closer to $100k than $20k if the OP gets invlolved in working the entire place.
   / New land... need a tractor!! #43
Yeah, I'm at $54K with no cabs.
   / New land... need a tractor!! #44
Just can not imagine tending to 200 acres with what $20k will buy "slightly used".
This is a little more than 20K but not much. While it may not be some peoples first choice, I can certainly imagine using it to tend 200 acres.
2014 Kioti RX7320 with FEL in NY for $24.9k listed on tractorhouse.com
   / New land... need a tractor!! #45
ovrszd is profound. You start where you start. This is Doc's "first" tractor. There are really only 25 acres to tend to. A 40hp to 55hp will do just fine. After he gets the bug, he will buy something bigger and something smaller. In the meantime, I wouldn't mind doing everything he wants top do with my 40hp New Holland.
   / New land... need a tractor!! #46
This is a little more than 20K but not much. While it may not be some peoples first choice, I can certainly imagine using it to tend 200 acres. 2014 Kioti RX7320 with FEL in NY for $24.9k listed on tractorhouse.com
That does seem like a pretty good deal actually. It's definitely the size I'd want for the acreage involved.
   / New land... need a tractor!! #47
gladehound is profound. I would buy that!
Wow. That Kioti you guys mentioned looks like a nice tractor. Bigger than I envisioned for what I was though. But the price and capability is tempting. You all are evil!!! ;) lol!!!
   / New land... need a tractor!! #49
Just go and sit on that Kioti, and drive it around a little. I'm sure you can resist the temptation. Those of us with 2 and 3 tractors have been able to resist temptation, or we would have 5 or 6 tractors by now - Right ???
   / New land... need a tractor!! #50
As you are looking at tractors like the Kioti, consider also Mahindra. Both are big beefy machines and good value for the money. Both very reliable. I bought my Kioti from Rick Wallace in Lake Ariel, PA just east of Scranton. I know it is a couple hours from your property but I cannot say enough about Rick as a dealer. He sadly no longer carries the Kioti line but he does carry Mahindra. Well worth a visit if you get up that way. Wallace Tractor and Equipment NEPA Compact Tractors Lake Ariel Poconos Honesdale PA
2018 LAND ROVER Range Rover (A50324)
2018 LAND ROVER...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2004 Ford F250 (A50515)
2004 Ford F250...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
Ih 490 Disk (A50514)
2008 Mazda CX9 (A50324)
2008 Mazda CX9...
