ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 33,724
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
I can't find the instructions that came with my two additional rear remote kits. But I specifically remember there was an order to the valve installations. I have one SCV and two FD valves. The original SCV had to go on the bottom of the stack. I don't remember if the instructions even stated a technical reason why. And that didn't matter to me. Rick's explanation is probably the reason. In your video he stacked his FD valve on top. Probably for the same reason?Without doubting you, this is news to me since SVC valves are stacked atop each other and the length of the adjustable cables remains more or less the same
Cf. The L6060's big brother.
In my case the valve lever slots are the same length so adjusting the cables simply put the lever in the center of the slot to get maximum movement each direction.
