NEW L48 REPLACEMENT RUMOR POLL
/ NEW L48 REPLACEMENT RUMOR POLL #21
curtisfarmer said:
Saw and held the new M59 brichur today, pretty cool. Looks like big L39, 148 cubic inch motor, 4k lift at pins, 12' hoe, factory thumb, 8,840 lbs. $47K.
I am getting another L48 and cannot justify the incremental cost. Just my 2 cents.
Only 1850 lbs heavier than a L-39, but 1300 lbs more lift at pins? (2,700 vs. 4,000 lbs) At center bucket that ought to be about 3200 or 3300 lbs, which is near 50 % more than the L-39. I hope it has 6k in curl. (weak point of L-39) Sounds tippy, but interesting.
/ NEW L48 REPLACEMENT RUMOR POLL #22
The brochure said 3k lbs. bucket center. Same Hyd. flow as L48, did not mention range speeds. Showed it with mower on boom arm, cool, but not useful as repostioning all the time would take forever. It does look big, and with loaded tires and other ballast, 10,000 lbs. trailers will be tough. I want to see one in person.
/ NEW L48 REPLACEMENT RUMOR POLL #23
Yeah, you are not going to move an M-59 with a 3/4 ton truck & 10K trailer, especially if you do the safe thing and ballast it to 10,000 lbs.
Considering the terrain we have in NH, ballasting my tractor was the smart safe thing to do.
/ NEW L48 REPLACEMENT RUMOR POLL #24
What kind of terrain do you have?
/ NEW L48 REPLACEMENT RUMOR POLL #25
It used to look like this, $50,000 later, it is shaping up
  • Stump_Piles_View_to_West_From_Future_Home_Post_Blast_10_29_06.pdf
/ NEW L48 REPLACEMENT RUMOR POLL #26
It used to look like this, $50,000 later, it is shaping up.
That's NH alright, but you definitley must have moved some of your larger boulders before you took the image. Our acreage in NH is identical. Granite is a stable and highly dependable crop. More rocksw appear every spring until you finally have enough thatch to hold them down.
It took me the whole summer and into the fall [not quite done] to get control of the the surface rocks on a new 3/4 acre woods clearing. By next summer, I should be able to run the riding mower over the terrain at level 6 and escape a blade hammering.
The Gardener
/ NEW L48 REPLACEMENT RUMOR POLL #27
The Gardener
My wife and I cleaned up about 1.5 Acres of bulldozed woods this fall. +40 loads in a big Terex off-road dump carried the stumps away from 5 cleared acres of thick hilly woods.
First I used the Borford grapple on the L-39 and hoe for some rocks, then the 6' box blade on an L3400, then the 7' HD york rake either on L3400 or my little B7200 with plenty of hand picking of rocks, roots and branches.
$300 in pasture grass seed was spread.
We will see what it looks like in the spring. We have another +3 more acres to clean and seed not counting a 1/2 acre backyard.
Sounds like a job for an M-59!
/ NEW L48 REPLACEMENT RUMOR POLL #28
/ NEW L48 REPLACEMENT RUMOR POLL #29
/ NEW L48 REPLACEMENT RUMOR POLL #30
Mike please Steve knows what he is talking about.theL39 is the end loader designation. Steve is the owner of Carver and I purchase thousands of dollars of parts for my rental fleet through his organization. He is very well connected to Kubota Corporate folks.
/ NEW L48 REPLACEMENT RUMOR POLL #31
theL39 is the end loader designation,my bad typing. The L39 is the model pictured with the TL1000 end loader designation was a mistake that needs edited out of the previous post. It wouldn't let me retact it without erasing the entire paragraph. Mike is correct picture needs to go Steve.
/ NEW L48 REPLACEMENT RUMOR POLL #33
Thanks! I have been checking. Even checked this morning but only in the TLB section so not sure if it was there or not. Thanks for the heads up.
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
2009 Infiniti FX35 AWD SUV (A64557)
2009 Infiniti FX35...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
Bandit 250XP Wood Chipper (A63689)
Bandit 250XP Wood...
2006 JOHN DEERE 700J LT CRAWLER DOZER (A65053)
2006 JOHN DEERE...
2018 RAM 2500 (A65643)
