Buying Advice New L3560 Limited and Standard Versions
   / New L3560 Limited and Standard Versions #111
i would be putting on the Titan Turfs. Salesman said they were the exact size of the R4's. Based upon that i understand that would be roughly 94 inches in height. For those that have purchased the 3560 cab tractor with R4's i would appreciate a measurement. Your help is appreciated. Thank you so much. Brent
Unless Tractorable has finally pulled the trigger I think I'm the only one in the thread that's actually purchased one. I also don't have a single bit of level smooth ground, so I wouldn't trust my own measurement if I gave one.
However, there should be no difference between the LE and standard models when it comes to height. I suggest starting a new thread "L3560 height on R4s" or something like that. Someone out there has a L3560 on R4s and a nice smooth level surface to get a good measurement from.
   / New L3560 Limited and Standard Versions #112
Good evening!
Looking to purchase a 3560 LE. For those that have purchased would you be able to provide height of tractor from concrete surface to top of cab. i have 95 inches clearance. I believe there is room but maybe by an inch? Your help is appreciated. thanks Brent
I have a L3560 Cab and the industrial R4 tires. I have an 8 foot door height.....and paid particular attention to the height.....so I could fit into my pole shed. I spend the winter in AZ and my tractor is in MN.....so I cannot put a tape on it from here. But IIRC I measured about 94" and had some 2 to 3" of clearance under my overhead door. I have more door clearance with this cabbed tractor than I did with my O.S. JD 3320 w/ the ROPS. Wish I could put a tape on it to show you a pic......and my memory is a bit foggy on the actual dimensions. Good luck.
   / New L3560 Limited and Standard Versions #113
Finally took a pic of my door and my tractor going under it. The door measures EXACTLY 96" high opening.....and the tractor cab clears by about 5" with industrial tires on my tractor. Pic to follow. There is a slight (1") angle at my door.....but even with this rise in the concrete the tractor has 5" clearance under the 8 foot opening.
   / New L3560 Limited and Standard Versions #114
That extra clearance could be a good thing when we get allot of snow. Could make all the difference needed to clear. ;).
   / New L3560 Limited and Standard Versions #115
I didn't purchase the LE, but I went with the standard version. I liked the few extra features and for me, it was easier just to have everything factory installed.
   / New L3560 Limited and Standard Versions #116
Congrats on your new tractor!!!! Pics please!!!! :)
   / New L3560 Limited and Standard Versions #119
The LE version was not available when I bought my Grand L 3560HSTC. If it was.....I think I would have bought it instead of my Grand L. Not for the savings in money....but those mirrors and lights are quite exposed to the brush and timber on my land. I dont need the light and the mirrors are most often a nuicance. Still....I like the tractor and I'm learning to work around these things in the brush.
   / New L3560 Limited and Standard Versions #120
I bought a 3560 LE cab a couple of months ago. Added back the mirrors and cab lights. Worked it into the deal for only $175 extra.
Love the tractor!
NEW HOLLAND TS6.120 TRACTOR (A51406)
NEW HOLLAND...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2014 Ford F-150 Pickup Truck (A53422)
2014 Ford F-150...
2169 (A54757)
2169 (A54757)
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
