Buying Advice New L3560 Limited and Standard Versions
   / New L3560 Limited and Standard Versions #122
I'd love to hear some more feedback on the new 3560 LE models. How are they treating you? Any new strengths or weaknesses discovered?
   / New L3560 Limited and Standard Versions #123
That's not true according to Messick's, in Neil's video. It has the exact same transmission as the standard model.
   / New L3560 Limited and Standard Versions #124
I love my L3560 cab.
   / New L3560 Limited and Standard Versions #125
I just hit 109 hrs on my l3560 hstc LE. I still love it. Feels stronger than my old mf135. The antenna stud is week. I thought it was loose one day so I reach out of the cab to tighten it and broke it off. I got another on the way from an online marine shop.
   / New L3560 Limited and Standard Versions #126
have you broken a high mounted rear flasher yet?
I knocked out the lens on one side. Have since removed both brackets and lights.
   / New L3560 Limited and Standard Versions #127
Yes I have. I stopped at a pilot truck stop and they sell an assortment of flashers I picked up one to test and it fit perfect. I will get another next time I am by there. It’s was about $13. I am slowly getting interested in wiring up some work lights but I would like to use factory harness.
   / New L3560 Limited and Standard Versions #128
The LED hazards I got off Amazon for my cabbed Grand cause radio interference. Stick with old halogen bulbs if you listen to a radio. There were only 1 set of LED hazards I could find after a suprising amount of searching & they were chrome instead of black.
   / New L3560 Limited and Standard Versions #129
There is no controller or harness for front work lights on the LE, I ended up with two work lights(one front, one rear) running off the optional rear switch.
   / New L3560 Limited and Standard Versions #130
You need mirrors on ANY cab model, you don't need a right hand step (never used mine, never gotten off that side anyway, the loader tower is in the way. Don't need lights either, I changed my sealed beams out to LED's a long time ago. My tractors don't come with a mid mount pto and I have no use for one anyway.
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
2024 CATERPILLAR 242D3 SKID STEER (A52705)
2024 CATERPILLAR...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
